  • SN95 4.6L Mustang Tech
How much gear oil
  • Thread starter Thread starter StygianStang
  • Start date Start date Aug 24, 2004
StygianStang
97
NORTH ILLINOIS
Aug 24, 2004
  • Aug 24, 2004
is required when changing it?
Also, is it recommended to change the oil periodically when putting in 4.10's? if so, how often?
W
wei462
90
Hill AFB, UT
Aug 24, 2004
  • Aug 24, 2004
The owners man. says 3.75 pints. I just filled mine up this weekend and I stopped when I felt the fluid level with my pinky through the fill hole. As far as changing it out periodically, when I installed my gears, I changed the fluid out after about 500 miles or so. I didnt have any problems.
R
Rocketman
730
SoCal
Aug 24, 2004
  • Aug 24, 2004
I changed my gear oil when I installed an FRPP girdle. I used Royal Purple and poured it in until it came out of the stock fill hole in the front by the drive shaft which was a little over 2 quarts. I plugged the stock fill hole and went ahead and poured the rest of the 3rd bottle in. I had problems with fluid leaking from the little vent on the top passenger side of the axle housing. I drained out about a quart before it stopped. I don't see how they get 3.75 quarts in the owners manual. I should of stopped at 2 quarts. So, to answer your question, fill it until it comes out the stock fill hole or at least close to it and stop. You should have about 2 quarts or just a little over 2 quarts. Save the rest of the 3rd bottle for your next change.
StygianStang
97
NORTH ILLINOIS
Aug 24, 2004
  • Aug 24, 2004
Couple more questions.
Is there a break in period?
Besides the oil and gears, what else is required for 4.10's?
95Vert
1,785
North Mexico (deep south Texas)
Aug 24, 2004
  • Aug 24, 2004
no break in period, nothing else is required for 4.10s just traction, or maybe, just maybe a trac loc rebuild kit ($50)
StygianStang
97
NORTH ILLINOIS
Aug 24, 2004
  • Aug 24, 2004
I dont know what the trac loc kit is, but i was going to get this kit....
http://mustangtuning.com/moinkit8re.html
95Vert
1,785
Aug 26, 2004
  • Aug 26, 2004
yep get that
StygianStang
97
NORTH ILLINOIS
Aug 26, 2004
  • Aug 26, 2004
95Vert said:
yep get that
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
Dipstick Issue?
  • Sonic
  • May 2, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 5, 2026
WhiteCobra95
N
Metal Chunk in Oil
  • nlord
  • Nov 15, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Nov 15, 2025
nlord
N
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
