• Off-Topic Hangout
How To Replace Front Passenger Turn Signal Bulb 2012 Dodge Durango
  • Thread starter Thread starter ximportdriver
  • Start date Start date Sep 12, 2015
ximportdriver
20+ Year Stangneter
Oct 7, 2003
386
46
59
Rancho Cordova
Sep 12, 2015
  • Sep 12, 2015
Yes, its a HEMI.
I can't get this bulb out.
Online research a la You Tube et al has proved useless.
Any advice?
ximportdriver
20+ Year Stangneter
Oct 7, 2003
386
46
59
Rancho Cordova
Sep 12, 2015
  • Sep 12, 2015
Applied constant force for about 60 seconds, pulling really hard, and it disconnected. I was afraid that applying such force would shatter the bulb, but it didn't. #newb
ximportdriver
20+ Year Stangneter
Oct 7, 2003
386
46
59
Rancho Cordova
Sep 12, 2015
  • Sep 12, 2015
Unfortunately, despite changing the bulb, I'm still getting a message alert that states the bulb is burnt out. All of that time and energy down the drain.
JoeDaddy
Honey, I need a check for $30k to pay the hooker
760
647
144
SW Michigan
Sep 14, 2015
  • Sep 14, 2015
To change the bulbs on my avalanche, i have to take the whole headlight off
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Sep 15, 2015
  • Sep 15, 2015
As cars have gotten smarter apparently they are still stupid.
Does the bulb actually work?
I'm confused did you change it because of a message or because the bulb was burnt out?
ximportdriver
20+ Year Stangneter
Oct 7, 2003
386
46
59
Rancho Cordova
Sep 15, 2015
  • Sep 15, 2015
Well, it has two functions. One function works--and worked with the old bulb. The other function, the turn signal, is not working.
Bullitt347
I have been doing it wrong this whole time
4,020
3,018
204
Middle of Maine
Sep 15, 2015
  • Sep 15, 2015
probably the socket the bulb goes into is bad
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Sep 16, 2015
  • Sep 16, 2015
Could be low on blinker fluid.
ximportdriver
20+ Year Stangneter
Oct 7, 2003
386
46
59
Rancho Cordova
Sep 22, 2015
  • Sep 22, 2015
So, turns out the repair I had 3 weeks ago to replace the "TPM" for a startup issue had a loose wire that was causing the front turn signal to throw an error.
Dealership fixed by properly affixing the wire.
  • Off-Topic Hangout
