How to replace starter?
  • Thread starter Thread starter sgw_88FoxGT
  • Start date Start date Aug 2, 2008
sgw_88FoxGT
43
  • Aug 2, 2008
How do I take out my starter? I got an '88 GT. I need to put in a new starter but I can't figure out how to access the bolt further from the ground. Do I need to remove anything else?
dcurtis
688
Aug 2, 2008
  • Aug 2, 2008
I removed my passenger side wheel, and used about 2 feet of extensions, I lined it up on the bolt while my buddy standing beside the car torqued it, there is a hole that will go right to it, you will need some extensions and a swivel. Thats the only way I could figure out, someone else might know another way though
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 2, 2008
  • Aug 2, 2008
Jack up the car. Put jackstands under it. Go under the car. Remove the bolt holding the starter cable on. Then take out the two bolts holding it in place. Once your under the car if it takes you more then 5 minutes your overthinking it. No need to take the wheel off or remove anything at all. Good luck!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 2, 2008
  • Aug 2, 2008
The top bolt is a little trick to get at. As metioned, some extensions and a 1/2" universal socket are what you need.
Use some tape to hold the bolt in the socket when you go to put it back together. That will keep the bolt from falling out of the socket. If your universal socket is worn and limp, wrapping some tape around the outside of it may help.
Reactions: 85rkyboby
sgw_88FoxGT
43
  • Aug 4, 2008
I figured out a way to get to the upper bolt on the starter without multiple extensions and without taking the wheel off. I got the smallest ratchet I had (about 7 inches long) and used just a 3 inch extension. I got under the car and reached through the K-member to get the socket on the bolt and then I was able to get the bolt of in 1/8 turns. Took about two minutes but I got it, got the new starter in and it works great.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 4, 2008
  • Aug 4, 2008
Cool, told you it was easy!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 4, 2008
  • Aug 4, 2008
A short wrench (ratchet wrench especially) makes short work of the top bolt.
derrick gil
67
Aug 5, 2008
  • Aug 5, 2008
Mine has a brand new 331 stroker, and the ash tray does work, its never been broken. 89GT convertible with 90,000 miles.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 5, 2008
  • Aug 5, 2008
And this has to do with what?
derrick gil
67
Aug 5, 2008
#10
  • Aug 5, 2008
  • #10
It quoted the wrong thing, look below his original statement. Just messing with him, dont take it too serious.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 5, 2008
#11
  • Aug 5, 2008
  • #11
I wasen't just didn't know what the heck you were talking about.
sgw_88FoxGT
43
#12
  • Aug 6, 2008
  • #12
Well keep that ash tray in good shape. You may have the only one still working. I'm sure that ash tray alone will increase the value of your car by like $10,000-$20,000.
Mustank
166
Germany
Aug 6, 2008
#13
  • Aug 6, 2008
  • #13
:OT:
You can buy repair kits - and even new doors from 50resto......I'll let you know how well it works.
Mine was actually working until one day when I was crawling out from under my dash after installing a new clutch quadrant and fell back....guess where my hand landed. I was so happy to find a car with a working ashtray door too...
:OT:
I think the other guys already covered the top starter bolt. The most important thing is a steady hand and PATIENCE!
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Engine Starter ring gear depth. 3/8 or 3/4 inch?
  • 92Rustang
  • Aug 4, 2025
Fox 5.0 Mustang Tech Aug 22, 2025
Rcdgl
R
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
