Husky HVLP gun
  • Thread starter Thread starter SFI-Mike
  • Start date Start date Aug 22, 2004
SFI-Mike
Westport, CT
Aug 22, 2004
  • Aug 22, 2004
Has anyone used Home Depot's Husky HVLP gun and does it actually work? I was thinking about getting one to learn on
BlueMonster65
385
Connecticut
Aug 22, 2004
  • Aug 22, 2004
i wouldn't use it to paint a car. i recommend a sharpe cobalt HVLP gun as an entry level gun. you can get surprisingly good results, its not expensive either about $150. if you buy a low quality gun to start with it will be frustrating and difficult to get decent results. another thing to consider is that HVLP guns require a very large air compressor capable of delivering a minimum of 11scfm at 40psi. most new crafstman and 110v cambell hasufileds are incapable of providing this. a good compressor available at home depot is the husky 60 gallon 7hp 220v. it is made by cambel hausfield and is good for painting and most other auto work. if your compressor is smaller get a standard pressure paint gun. it will creat more overspray but your paint job will come out much better than if you try to use a HVLP gun without adequate air.
67stangvert
177
Chicago, Illinois
Aug 23, 2004
  • Aug 23, 2004
60 Gallon?
I recently picked up a Warner Conversion HVLP gun to start automotive painting and a 33 gallon 6hp Craftsman compressor to begin painting. The gun was $130 and the compressor was $300. I was under the imnpression, until 6 months ago, that you need lots of push to run an HVLP paint gun. It is not true. The conversion paint guns require less than 8 CFM at 40PSI to run. My cousin who has painted cars for years turned me on to this and prevented me from spending alot of money I did not need to spend and has worked well so far.
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
D
1996 gt mustang block temp vs coolant temp
  • Dkuehn
  • May 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 22, 2026
squeak93
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
W
2.3l cooling fan questions
  • waxman
  • Jun 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 27, 2026
AeroCoupe
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
