  • SN95 4.6L Mustang Tech
HVAC Issue
  • Thread starter Thread starter black2002gt4.6
  • Start date Start date Jul 26, 2010
black2002gt4.6
  • Jul 26, 2010
I usually don't drive with the A/C on, but recently when I use it I am having a problem. Whenever I am cruising or idling my A/C works perfectly. The issue I am having is when I am accelerating. The A/C blower diverts the air from the front vents to the windshield & floor vents. When I let off the accelerator the air goes back to coming out of the front vents. Does anybody have any idea what is going on?
nyuk98gt
1,427
Chesterfield, MO
Jul 26, 2010
  • Jul 26, 2010
black2002gt4.6:
Welcome to StangNet!
Yes, the ventilation doors have vacuum-powered motors. At light or steady throttle, you have plenty of vacuum so the doors stay where they are. When you step on the throttle, the vacuum drops and the doors start swinging like an old saloon when the drovers come to town.
Basically, you have a vacuum leak. You need to follow the tubing (it is tiny) from the engine bay (near the firewall) and back behind the radio (you may need to remove the radio) to find the vacuum Xmas tree. Maybe a hose has fallen off or the supply line has a crack in it.
I don't have any pics (because I don't have access to my shop manual). Your local library may have a subscription to AllData and there you can get a nice schematic of the vacuum tree.
HTH,
Chris
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 26, 2010
  • Jul 26, 2010
def vacuum leak +1
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 26, 2010
  • Jul 26, 2010
+2 on the vacuum leak. There is a check valve in the AC control vacuum line between the vacuum res and the intake manifold. The purpose of the check valve is to maintain vacuum inside the vacuum res. I suspect either the check valve is bad or the vacuum leak is after the check valve.
Note, the vacuum res is in the passenger compartment right hand side. It is well up under the dash and can be difficult to access without removing the dash.
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
  • Gulftown980x
  • Jul 29, 2026
squeak93
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
