  • SN95 4.6L Mustang Tech
HVAC vent problem
  • Thread starter Thread starter Snikt89GT
  • Start date Start date Mar 25, 2007
Snikt89GT
264
Deland, Florida
Mar 25, 2007
  • Mar 25, 2007
I'm having a minor issue with the HVAC on the new 04 GT I just bought. When the HVAC is turned off, outside air is getting in and coming out of the floor vents. The airflow is 0 at idle and increases with vehicle speed, so the blower motor isn't on it's just coming in.
According to the ford service manual no air should be coming in from the outside when the switch is off.
When OFF is selected:
The air inlet door vacuum control motor is at full vacuum, closing off outside air from entering the passenger compartment.
The panel/floor door vacuum control motor is at full vacuum and the panel/defrost door vacuum control motor is at no vacuum, closing off airflow to the defrost duct, side window demisters, floor duct and instrument panel A/C registers.
The A/C compressor will not operate.
The blower motor is off.
Anyone else have this problem? What should I check?
Thanks
J
Jakes
84
  • Mar 25, 2007
---------------- snip ..................
Not to sound like a smart a$$....but, You got the service manual. What does it say to check?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 25, 2007
  • Mar 25, 2007
check to see if the vac line to the motor is ok, and see if the door is closing.
Snikt89GT
264
Deland, Florida
Mar 25, 2007
  • Mar 25, 2007
Yes I have the manual but most of it is in "ford speak" where you need 1000 rotunda tools, etc.. I was looking for someone who has real world experience doing something like this
Snikt89GT
264
Deland, Florida
Mar 28, 2007
  • Mar 28, 2007
I just pulled the line off while the car was running from the air inlet door vacuum motor and it's getting vacuum. How can I check if the door is closing or not? Not a whole lot of room to work in there
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
E
Noise near blower motor behind dash?
  • Ethereal_Zer0
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Ethereal_Zer0
E
F
WILL HEAT WORK WITH NO VACUUM
  • Foxbodychris90
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 17, 2024
Foxbodychris90
F
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
