Hypertech chips
  • Thread starter Thread starter mustangmadness
  • Start date Start date Mar 5, 2007
M
mustangmadness
  • Mar 5, 2007
Does anyone know if there is a difference with Hypertech chips. I am looking at one for an 88 5.0 5speed. I have an 89 5.0 5speed. Will it work as designed?
Thanks
Matt
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 6, 2007
  • Mar 6, 2007
It may or may not work, but it will be a waste. Bump your timing to 14° and forget about one of those chips. The gain you may feel probably won't be any different than what you'll feel by advancing the timing, and it won't cost you a penny to do.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 6, 2007
  • Mar 6, 2007
Since you are Mass Air, get a bigger MAF. A trip to the junkyard will bring some good results.
On a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
Aluminum driveshaft: (courtesy of shawn13) It needs to be from a 92-93-94 Aerostar AWD and you will need the u-joint, part #353 from NAPA. It should bolt right up after the u-joint swap.
*1.) metal flange adapter
http://www.kustomz.com/cat3.html
Buy the TR70 for $44.95.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
LB0193
171
IL
Mar 6, 2007
  • Mar 6, 2007
my 91 came with one, i plan on pulling it off, they are useless.....i can bump the timing myself
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
  • brandyn200
  • Jun 20, 2026
AeroCoupe
G
Fox Looking for old Hypertech part
  • GOvert
  • Jun 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2025
gkomo
Electrical need help with a part number
  • alutwon
  • Jan 27, 2026
Fox 5.0 Mustang Tech Jan 27, 2026
alutwon
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
