I Need Help
  • Thread starter Thread starter GodZilla37
  • Start date Start date Jul 23, 2005
G
GodZilla37
  • Jul 23, 2005
my turn signals stopped working when i started it today. checked the fuses all fine but i turn my key halfway they work and the engine light gas light in the lower right area of the console work when i turn it all the way they dont. i took it all apart and slide the ky shaft thingy out and it looks to be ok. would i just have to change that part to solve the problem or can anyone suggest somthing.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 23, 2005
  • Jul 23, 2005
Replace the ignition switch, it is the problem
There is a FREE recall on Ford ignition switches. They overheat and sometimes catch fire.
Copy down you VIN number and call the Ford dealer nearest you. Tell them you want to see if the ignition switch recall for Fords & Mustangs was done on your car. They will ask for the VIN number & check it against the master database. If it isn't in the datbase, then you can schedule an appointment to have the switch replaced for free. The TSB is #95S28, and don't let them tell you that they don't do that anymore...
G
GodZilla37
  • Jul 23, 2005
but
i already have had the ignition switch changed and the cats changed due to recall back in 98. so what do i say now wont it be on record that i had it done.
the lock cylinders seems ot be where the problem is it seems to cut out after you turn it all the way ( the turn signal cuts out ) the tunring on the car part is fine
HISSIN50
34
129
Jul 23, 2005
  • Jul 23, 2005
The ignition switch might have gone south again.
Good luck.
G
GodZilla37
  • Jul 24, 2005
did you mean if it is?
not sure i understand
HISSIN50
34
129
Jul 24, 2005
  • Jul 24, 2005
I think that he means that if the dealer's database does not have it logged that you already had the recall work done, then you can have it done gratis (since it is a recall item which has not been done yet).
If they look up the car's VIN and see the recall switch was already done, then you are probably out of luck on having them do the work and supply the part for free.
The switch is like 10-15 bucks, so no huge deal.
Good luck.
G
GodZilla37
  • Jul 24, 2005
oh ok thanks.
i found a webpage that walks you through on what is involved in changing one only problem is that it has two tamper-proof Torx screws. it also say you can buy them from napa. i hope i can but it seems like a waste of money to use it one time then thats it but cheaper then letting the dealer fix it.
hmmm i thought it would be the lock cylinder but it sounds more electronic so i guess it would be the ignition switch.
for $10 - 15 buying new is the safe bet
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
