I need some help!
  • Thread starter Thread starter coddredb
  • Start date Start date Oct 7, 2008
C
coddredb
  • Oct 7, 2008
I have been restoring a 68 coupe for about five years now to be a daily driver. I just recently got the car where its able to drive. I'm not by any means an expert on any mechanical device so I've done the majority of the restoration and had my uncle put a 302 hi output out of a 67 mustang and a 4 speed transmission that I bought from a guy that is a retired amateur racer. The problem I'm having is that I drive on an interstate at 65 to 70 mph. at these speeds the cars is running at a fairly high rpm and I would like to know if I need to put an overdrive on the 4 speed or do I need to upgrade to a 5 speed tranny in order to get the rpm down at those higher speeds.
xoxbxfx
3,959
Southlake, TX
Oct 7, 2008
  • Oct 7, 2008
Go with a 5 speed.. You can pick up a t5 for pretty cheap. It is a great daily driver transmission.
2000GTdriver
47
Mile High City, Colorado
Oct 7, 2008
  • Oct 7, 2008
I would get a 5-speed, an add on overdrive is way more expensive. I am glad you are driving your Mustang, too many fun cars are stuck away in storage!
zookeeper
3,415
63
109
Rogue River, Oregon
Oct 7, 2008
  • Oct 7, 2008
Rather than go to all the trouble of swapping transmissions, why not just swap rear gears? It's cheaper and faster and you can do it in a couple hours.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
Upgrade Advice on an 89 GT Convertible NJ
  • SteakDad
  • Apr 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 18, 2025
limp
