Engine Idle issues
  • Thread starter Thread starter Dnuke
  • Start date Start date Mar 8, 2020
First Prev 2 of 2
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Mar 14, 2020
#21
  • Mar 14, 2020
  • #21
Dnuke said:
...I also hooked up a vacuum gauge and it reads below normal (13-16 in hg) bounced around in that range.
Vacuum leak, 13-16 is too low at idle.
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Mar 14, 2020
#22
  • Mar 14, 2020
  • #22
Jrichker’s surging idle checklist is where you need to start step by step And in order.
As far as the pressure gauge, I think the one in my car has no core in the Schrader valve. If the glass gets broken when driving, that would be really exciting, so I need to get a core and cap as soon as I am done tuning.
If your car was modified, I would suspect it needs more idle air than the IAC and the throttle plate setting can supply. Similar year trucks had a plate with adjustable screws, or the gasket or IAC wall can be modified for more air flow with big cams.
But the list should get you running great without that.
Reactions: General karthief
barry2020
Illinois
Mar 14, 2020
#23
  • Mar 14, 2020
  • #23
Dnuke said:
Definitely appreciate all the ideas. I will try anything. The iac is brand new. TB has a sticker on it it to not clean. Is it still ok to clean? I have had it apart when I changed the egr and iac to semi clean the ports ( without cleaner) and put new gasket on then put it back together. Really just want to know if it ok to clean with TB cleaner? Thanks for all the input
Yes it is ok to clean but you must use a throttle body cleaner, do not use carburetor cleaner. All auto parts store have throttle body cleaner, there is a special coating inside a throttle body, carburetor cleaner will remove it, that is why you have to use throttle body cleaner which does not remove the coating.
Reactions: Dnuke and General karthief
7991LXnSHO
7,387
2,746
194
Kearney, NE
Mar 15, 2020
#24
  • Mar 15, 2020
  • #24
I thought it was because of possibly chemically melting the plastic and electronic in things like the IAC and MAF that the right cleaner is needed.
Either way, it’s a good reminder you put up.
First Prev 2 of 2
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Nov 16, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
mikeah
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
