  • SN95 4.6L Mustang Tech
Idle surge issue
  • Thread starter Thread starter baggett3_27
  • Start date Start date Nov 5, 2010
baggett3_27
35
RAF Lakenheath, UK
Nov 5, 2010
  • Nov 5, 2010
I just installed my Vortech S/C today. After the base tune it is surging at idle. Can I adjust the MAF to solve this problem, or do you think it could be something else? It is a 99 GT with a lightning MAF.
nyuk98gt
1,427
Chesterfield, MO
Nov 5, 2010
  • Nov 5, 2010
baggett3_27:
Disclaimer: not a supercharger guy (but a good reader of tech threads).
Problem could be IAC flow not being quite right, backwash into the MAF (depends on the location of the blow-off valve return into the intake tract), disturbed air at the inlet filter (is it protected from 'fan wash'?), a small vacuum leak in the intake tract, or a MAF function that is not quite right.
You don't mention whether this is a suck-through or blow-through MAF but that is important info for the smart people who know about superchargers. Are you doing the tuning or can you just make minor adjustments to a 'canned' tune? Can you post pictures of the intake tract (if it is not a stock Vortech set-up)? Details matter when it comes to exorcising the idle demons.
HTH,
Chris
baggett3_27
35
RAF Lakenheath, UK
Nov 5, 2010
  • Nov 5, 2010
It is a suck through MAF with anderson power pipe, straight discharge with the bosch by-pass valve.
baggett3_27
35
RAF Lakenheath, UK
Nov 6, 2010
  • Nov 6, 2010
I cannot find a vacuum leak. When I disco the MAf the car stop surging and idles fine, but bogs down when I throttle it. As soon as I hook the MAF back up it begins surging again. Could this be a tune issue?
baggett3_27
35
RAF Lakenheath, UK
Nov 6, 2010
  • Nov 6, 2010
I forgot to mention the exhaust smells like pure fuel.
nyuk98gt
1,427
Chesterfield, MO
Nov 6, 2010
  • Nov 6, 2010
baggett3_27:
Thanks for the additional info. Since you've checked for vac leaks (none) and the unplugged MAF gives pretty good idling and the exhaust smells rich then it has to be the tune. Call up your tuner and ask what items he wants datalogged so you can provide him enough info for a tune adjustment. Of course, if you're doing the tuning then let's discuss datalogging details.
Chris
baggett3_27
35
RAF Lakenheath, UK
Nov 6, 2010
  • Nov 6, 2010
I ordered a base tune from VMP to get me to the dyno, but I haven't received it yet. I do have the SCT tuner with livelink, so I can datalog. I'm also waiting on the SCT PRP I ordered to fine tune the car. I'm in the UK so there are no SCT tuners, but I have dyno shop that says they can do it if I with the SCT software. What are the things I should datalog for tuning?
nyuk98gt
1,427
Chesterfield, MO
Nov 6, 2010
  • Nov 6, 2010
baggett3_27:
Sorry, I missed your location. Justin at VMP is a talented fellow when it comes to tuning so you made a good choice. The dyno tune will, presumably, keep your engine safe for heavy- to full-throttle. The around town driving is often challenging but, with the PRP, you can do it with some time and effort.
OK, the IAC controls the idle speed and spark is used to trim idle speed. There are a bunch of modifiers for IAC (idle air), cold idle conditions, and warm idle conditions. You will see all of these in the PRP (Advantage) parameter list. First thing is to tune the MAF function. "Everything" depends on an accurate MAF function. Also, don't forget to sign up at sctflash.com for the ProRacer forum (it is available only to PRP owners and SCT dealers). Lots of info there and helpful people, too. Once you get the MAF sorted out and it is perfect (<--not exaggerating) you can start working on the idle. That will be datalogging the following: isc_air, isc_air_correction, RPM, spark, STFT1, STFT2, idle_speed_commanded, load, MAF, ECT, spark source, ECT, IAT. With these parameters, you will see what the IAC is being told to do. If the isc_air_correction is too high (+/-) then you have to adjust your isc_air_N and isc_air_D tables or the isc_air table. Justin can give you some good direction (better than me since I have not tuned a supercharged engine - see disclaimer, above). You can also send your datalog to VMP and let them review it and give you some things to look at. Data is vital when tuning our cars (any late-model car). You have a laptop to collect the data, yes? The XCal can only hold a small amount of data so a laptop is pretty much required.
OK, that should get you thinkin'.
Chris
baggett3_27
35
RAF Lakenheath, UK
Nov 6, 2010
  • Nov 6, 2010
Yup I bought a laptop just for tuning. I'm sure I'll have lots of questions when that time comes, but Justin's tune should give me a good starting point. I can't wait to put down some power.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:22 PM
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
