  • SN95 4.6L Mustang Tech
idle surge
  • Thread starter Thread starter T2000
  • Start date Start date Mar 10, 2007
T
T2000
Mission,BC
Mar 10, 2007
  • Mar 10, 2007
whats the deal with idle surge, i gots it.
likes to dance around idle, but sometimes its fine.
its a stock GT with longtubes and exhuast.
any ideas
sgarlic
3,085
Mar 11, 2007
  • Mar 11, 2007
Replace or clean IAC motor, reset the PCM properly, then come back and let us know if it still does it.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 11, 2007
  • Mar 11, 2007
does the idle surge when the a/c is on ( a/c is on in the two a/c positions and in the defrost and mix modes)
if it only does it in those modes then a low freeon charge can cause this. what happens is the a/c system short cycles and the pcm can not react fast enough to adjust the idle.
T
T2000
Mission,BC
Mar 11, 2007
  • Mar 11, 2007
ughh, what is the iac and the pcm
D
darkside03gt
851
Sacramento CA
Mar 11, 2007
  • Mar 11, 2007
IAC is the idle air controll valve on the front of your T/B and the pcm is your computer
Mike97gt
it doe snot
10,633
Mar 11, 2007
  • Mar 11, 2007
did you try and see if it only happens when the a/c compressor is running?? very common for this to happen.
T
T2000
Mission,BC
Mar 12, 2007
  • Mar 12, 2007
i tryed that
and it did surge when i reached in and turned the defrost on
hopefully thats it.
thanx
00GTpony
162
  • Mar 13, 2007
also make sure, ur not misfiring on any cylinders.. My idle was jumpin around as well, then i found out my 2nd cylinder was misfiring, and i fixed it, now the idle doest move.
Fog horn sound
  • brandon4v
  • Jun 22, 2026
SN95 4.6L Mustang Tech Jun 23, 2026
squeak93
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
Idel control valve
  • miser143
  • Oct 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
General karthief
