ignition locked
  • Thread starter Thread starter 93lx_Mumblez
  • Start date Start date Aug 24, 2008
9
93lx_Mumblez
  • Aug 24, 2008
so i got a 93 hatch and the ignition is locked and its not unlocking...i tried everything....im thinking about replacing it but i dont know how to take out the cylinder lock....anybody know of anything that could help me out
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 24, 2008
  • Aug 24, 2008
Grab the steering wheel and shake it hard as you try to turn the key. Sometimes the wheel locking mechanism jams hard and the wheel needs to be moved for the ignition to move.
9
93lx_Mumblez
  • Aug 24, 2008
yea i tried that for like 30 mins and nothing...the day before it got locked but i got it to unlock but it was hard...
HISSIN50
34
129
Aug 24, 2008
  • Aug 24, 2008
And to replace the cylinder easily, you need to get the ignition unlocked, so there's your catch 22.
Mike's advice is what I would try. I might even put the front in the air to unload the front tires and make the wheel turn just a hair easier. If your column is loose (common issue), try gently moving it up and down and side to side to see if that helps.
Good luck.
93 LX
3,081
Norwalk, CA.
Aug 25, 2008
  • Aug 25, 2008
You can replace the cylinder if you dont mind doing a little more work than turning the key. Remove the column's plastic crap. If you look under the lock cylinder you will see a small hole with a pin. Get a punch the same size as the whole. You need a heavy hammer hit the punch and drive in the pin.
Here is where things get tough. Once you hit the pin the part of the lock that turns the switch will sear off and stay in the switch. Using a pair of long nose pliers you can reach down the place where the lock cylinder was and fish out the broken piece. Take notice on how the switch gear is positioned. When you get the new cylinder you have to turn it to the run position. Note the position of the end of the cylinder. Turn the switch to the same position and slide the new lock in. I have done this to 3 different Stangs and it works everything. I have also done this in the bone yard to get the wheel to turn.
9
93lx_Mumblez
  • Sep 11, 2008
thx i got it fixed the other day... i took apart everything but the ignition switch cause that thing would come off for nothing so i put everything back together and go a wrench and turned that thing with the key in it and BAAM it worked =]
93 LX
3,081
Norwalk, CA.
Sep 11, 2008
  • Sep 11, 2008
cool beans man!
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
