  • SN95 4.6L Mustang Tech
Ignition problem...
  • Thread starter Thread starter Tally_4.6
  • Start date Start date May 20, 2006
Tally_4.6
195
Orlando
May 20, 2006
  • May 20, 2006
Ok, when i start my car it lags. I tested the battery and alternator awhile back and found out the alternator is bad. I already replaced the alternator and the battery is good. Yesterday i tried to start it and it would'nt start, turn key and nothing. Got a jump from a friend and after 3 turns it started up. It's really pissin me off cause it could leave me somewhere. What could it be, starter, ignition switch, plugs?
thanks
Nater
239
Maplewood, MN
May 21, 2006
  • May 21, 2006
I would say that if you had to get a jump, the battery is on its way out. How did you test the battery? Just hook it up to a voltmeter or did you do a load test on it?
Tally_4.6
195
Orlando
May 21, 2006
  • May 21, 2006
I don't know, i took it to a place and had it tested twice and it said it was good.
Whats the diff. between load testing and voltmeter?
Nater
239
Maplewood, MN
May 22, 2006
  • May 22, 2006
A voltmeter will show the voltage, but if it has a bad cell it would not show up until you put a load on it. When I used to work at an auto parts place, the battery would show to have a full charge but once you place it on a load it would fail. Load testing is just as it states--putting a load on the battery.
Tally_4.6
195
Orlando
May 23, 2006
  • May 23, 2006
Well i believe i found my problem. Did a load test on the battery and its a good battery, starter is good too. The problem is the battery isn't putting out enough cranking power, I need a bigger one. I'll replace it in a few days and see what happens.
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 23, 2006
A Optima red top battery should have more than enough cranking power!
Tally_4.6
195
Orlando
May 23, 2006
  • May 23, 2006
I also bought some new NGK plugs today. Is it important that i buy motorcraft plugs since its recommended or does it really not matter?
A
aparker813
51
  • May 25, 2006
i vote you take it back to c2 and just make them do it
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 25, 2006
The Ford Motorcraft spark plugs work the best on are cars.
They are made by Autolite I do belive. I am running the Autolite 764's
with no problems at all.They work perfectly.
Tally_4.6
195
Orlando
May 25, 2006
#10
  • May 25, 2006
  • #10
I guess i'll return em when i get a chance and get some Autolites.
What the deuce!!
A
aparker813
51
#11
  • May 26, 2006
  • #11
What the deuce!!
<<<TMCA (and very little TI)
Tally_4.6
195
Orlando
May 26, 2006
#12
  • May 26, 2006
  • #12
Yeah i've seen you on TMCA.
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
