Ignition WireUnder Steering Wheel (too much?)
  • Thread starter Thread starter Strype
  • Start date Start date Apr 13, 2007
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 13, 2007
  • Apr 13, 2007
How much is too much to run off of it? I have a water temp guage, an oil pressure guage and a monster tach hooked up now. I want to know if my 95 Taurus fan is too much of a load for the system. Anything I can buy from Autozone or somewhere to help the load?
Also, even though the fan temp control has a fuse from the battery to the fan, should I run a fuse on the ignition wire also and if so what size?
gunmetal5.0
144
Chico, CA
Apr 13, 2007
  • Apr 13, 2007
How many amps is your alternator? Usually when you start getting into electric fans they draw a lot of extra current that a typical 65-86 amp alternator might not be sufficient for. That might be something to look into for you. Might consider a 100 amp+ unit.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 13, 2007
  • Apr 13, 2007
70 I think.
But would overloading that wire cause a short of any kind?
HISSIN50
34
129
Apr 13, 2007
  • Apr 13, 2007
If you are powering the fan motor from the ignition wires, that's not the greatest. You'd want a HD relay, which you install near the fan and/or battery. You can use your existing wiring but you will use it for the control side of the relay. Then you'd add a couple of short thick wires under the hood (battery to relay [fused] and relay to fan).
Good luck.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
  • dan50
  • Jul 18, 2026
dan50
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
