Info for 05-09 Mustang GT owners who have experienced total power loss (dead stalls) after 1-2 hours of hwy driving
purplegold90
Raleigh, North carolina
I don't know if this issue exists with all S197's or just certain year models, but I own a 2007 Mustang GT and I was plagued with this problem for approximately 3 years. It got so bad, that I decided it wasn't worth it and decided to put in storage and get something else. This was in 2017. I decided to go totally opposite from the mustang and bought a 2017 Focus RS. And that car was fun for a while, but there just isn't any substitute in my opinion for V-8 power. So, this past July, I decided to pull the Mustang from storage. I had nearly 2 years to think about the car and what other possibilities could be causing the sudden stalls. I will define these stalls a little better so that one can determine whether this is what is specifically occurring with their GT. The car is heavily modded. Without going over all the mods, I will say that there is nothing that has been done to the car that would be considered "out of the box" concerning the mods. I am running a Maggie blower (1900 TVS), the motor was completely rebuilt by a local performance shop in my area that worked solely on Mustangs (although I believe they have since branched into a few other vehicles, such as some Mopar cars), and do very good work. Before I started going to them, I was using another local performance shop who also had a very good reputation and also specialized in Mustangs. My issue was simple. Anytime I would driving on a hwy, and running the car consistently for say, 1-2 hours, at 75-80mph, probably 1 out of 3 times, the car would start to run rough, and within a few seconds, it would completely shut down. I eventually got used to this and would immediately get into the right line and try to pull off asap. Whatever was happening would never pop an engine light. I was running a tune, therefore I could always check any codes with my SCT tuner. After waiting for anywhere from 15 to 30 minutes, the car would usually start up, as if nothing had happened and I would continue on my way. So, when I pulled it from storage this past July, I decided to try one last thing. And if it worked, great. If it didn't, then I had decided that I would cut my losses and sell it, fully disclosing the issue I had been having. I decided to have the Aeromotive 340 FP I was running swapped out for a FR dual FP. I also had the stock sending unit swapped out for a new one. I needed a new battery as well, but those were the main two items and I had one of the local Ford dealers do the work. After that was done, I put it through every scenario I could think of where it had given me the stalling issue, and I have not experienced a single stall or the car running rough since this was done. So, for anyone who is experiencing anything similar to this, try changing out your FP and the sending unit and see if that clears up the issue. I will say that the wiring harness to my old FP module used very thin wires. I swapped out the FPM 3 or 4 times, but that never seemed to help. With the FR dual FP, I now have 2 FPM's. And while the FPM that comes with that kit appears to be the same, the wiring harness that connects to it uses a MUCH heavier gauge of wires than what was on the original FPM. It is just my opinion that the wiring setup which was used with the Areomotive pump were so thin, that when the car was driven for a couple of hours on the hwy, the wiring became increasingly hot, reaching a point to where it was unable to pass communication back and forth between the FPM, the FP, and the sending unit, causing a complete failure between these components, which caused the ECU to shut down the car. This is just my opinion. But if this sounds familiar to anyone, I hope this info helps.
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
F Proud 2kGT Owner Looking for Info The Welcome Wagon 1
wicked93gs Swapping a 3.7L v6 into my 1966 Mustang, looking for a bit of ECU info 2005 - 2014 Specific V6 Tech 10
J Help please 2006 mustang transmission info needed 2005 - 2009 Specific Tech 0
F 1966 mustang buck tag info 1965 - 1973 Classic Mustangs -General/Talk- 0
C First generation info for street driven 65 - 67 Mustangs. 1965 - 1973 Classic Mustangs -General/Talk- 8
H 1966 Mustang 289 flywheel info needed Classic Mustang Specific Tech 7
7 73 mustang blower build info needed 1965 - 1973 Classic Mustangs -General/Talk- 1
B Help! Wanna get a little info on trick flow heads and what i should expect from them. 1996 - 2004 SN95 Mustang -General/Talk- 0
B Help,anyone Know,balance Specs,for 96,3.8l Manuals Flywheel And Hormonic Balencer, And 97,auto.,flex 1996 - 2004 SN95 Mustang -General/Talk- 1
B Looking For Info On A 2003 Mustang Gt The Welcome Wagon 1
B Need Info On Transmissions For Mustang 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
F Heidts Mustang Ii Info And 429/460 Swap 1965 - 1973 Classic Mustangs -General/Talk- 6
429supercobrajet In Need Of Performance Info For A 96 Mustang Gt 4.6 1996 - 2004 SN95 Mustang -General/Talk- 7
Glocker23 Looking For Info On Carlisle Pa Mustang Show Regional Forums and Event Information 7
R 1968 Mustang Key Code Info 1965 - 1973 Classic Mustangs -General/Talk- 6
GeoSnake 2013 Mustang Week Info! Show Registration Open! Regional Forums and Event Information 1
Jordan Henriques New Member! Info, suggestions for my 1987 mustang gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
dbmac21 flywheel swap info on 67 mustang 200 cid Classic Mustang Specific Tech 5
FoMoCo17 1990 Mustang Gt: Stock Cam Degreeing Info Needed Fox 5.0 Mustang Tech 1
H have kits for mustang targa tops i buils custom for the car if you want info Special Production 3
MRaburn Marti Auto Works offers expanded Ford Mustang info StangNet Site News 0
geneo4116 JUST RECIEVED MY 2013 MUSTANG 5.0 AUTO 315 GEARS NEED PERFORMANCE INFO PLEASE 2010 - 2014 Specific Tech 7
redponyv8 mustang info 2005 - 2014 S-197 Mustang -General/Talk- 3
C Mustang color info Classic Mustang Specific Tech 3
B Smog info... Fox Mustangs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
A 40th Anniv Production info needed for 40th Anniversary Crimson Red Roush Mustang Special Production 2
1stanger1 89 5.0 swap into a 99 mustang any info?? Fox 5.0 Mustang Tech 7
T 94' mustang 6cyl 3.8l help/info SN95 V6 Mustang Tech 0
1993SSP Anyone have any info on a Ex FHP mustang for sale locally 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
S 1983 Mustang 2.3t swap info. 2.3L (N/A & Turbo) Tech 9
94-302-vert Tires for 65 Mustang - Info Needed Classic Mustang Specific Tech 9
J 1992 FORD MUSTANG GT/COBRA GT need info 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
MRaburn 2010 Mustang Debut Coverage & Ordering Info StangNet Site News 0
MRaburn 2010 Mustang Debut Coverage & Ordering Info 2010 - 2014 Specific Tech 0
pudman fun info about your mustang 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
N ANY INFO ON 2001 MUSTANG BULLITT PROTOTYPE?????HELP!!!! 1996 - 2004 SN95 Mustang -General/Talk- 8
C looking for info on mustang II swap Classic Mustang Specific Tech 3
reenmachine The "Mustang II" IFS Real Info & Debate Thread Classic Mustang Specific Tech 149
JTGrant Any info on new engine package for the Mustang? 2005 - 2009 Specific Tech 2
B Info. on Mustang engine horsepower 1996 - 2004 SN95 Mustang -General/Talk- 8
tapd117 Shelby GT Mustang Info From Ford 2005 - 2014 S-197 Mustang -General/Talk- 14
billison need info on classic mustangs Classic Mustang Specific Tech 28
F Looking for info on the 05, 06, and 07 Mustang GT's 2005 - 2009 Specific Tech 8
C Roush Help finding info on MY 00' Mustang Roush GT Special Production 3
05MGT 2007 Mustang! 28 pages of official info... 2005 - 2014 S-197 Mustang -General/Talk- 22
FoxRod87 2002 mustang gt need info 1996 - 2004 SN95 Mustang -General/Talk- 10
0 Motor Trend Info on the new Boss mustang 2005 - 2014 S-197 Mustang -General/Talk- 28
S 07-08 “Terminator mustang” any info? 2005 - 2014 S-197 Mustang -General/Talk- 10
4MuscleMachines Recaro Seats in 70 Mustang, need info.. Classic Mustang Specific Tech 5
SilverStallion Tech Info. On 2005 and 6 Mustang GT Needed Please - Looking at Buying>>> 2005 - 2009 Specific Tech 3
