  • 2.3L (N/A & Turbo) Tech
injector size?
  • Thread starter Thread starter manny
  • Start date Start date Dec 28, 2004
M
manny
590
TAMPA FL
Dec 28, 2004
  • Dec 28, 2004
what size is the injector on a 2.3 and could the next size injector come off an other ford vehicle?
project91
101
  • Dec 28, 2004
they should be 30+ pound injectors.
the only injectors that i could reccomend for you from another ford vehicle are the brown top injectors. i think they were on the turbo coupes.
35lb./hr
bhuff30
6,037
35
129
Olathe KS
Dec 28, 2004
  • Dec 28, 2004
I bet he is wanting to know what size the NA has. They are 14lb/hr injectors, and you can get some 19's from various 5.0's and tons of other ford vehicles.
M
manny
590
TAMPA FL
Dec 28, 2004
  • Dec 28, 2004
yes bhuff30 your on the same track that i'm thinking. this is my situation= a 1987 s/d efi used in racing at high rpm, head has been mild and ported, at end of race spark plugs are very white in appearance, not enough fuel. i think the injectors are at the 80% duty cycle now and i was wondering if i went with a bigger injector if that would help with getting more fuel? and also i plan on moving the ACT sensor from the intake manifold to the air inlet tube near the air cleaner where the air temp is much cooler. any help would be appreciated.
M
manny
590
TAMPA FL
Dec 28, 2004
  • Dec 28, 2004
sorry but i forgot something else. if the 19lb/hr would work what type of vehicle would they come out of? mustang,t-bird w/5.0 are just any ford vehicle with a 5.0?
bhuff30
6,037
35
129
Olathe KS
Dec 28, 2004
  • Dec 28, 2004
I know the HO 5.0 got 19lb/hr injectors with the correct resistance. I beleive they had orange/tan tops, as compared with your current injectors which are gray tops. You should be able to easily get a set of injectors from a 5.0 guy that threw in bigger injectors or look around the junk yards for orange/tan tops. They will probably look like this: http://cgi.ebay.com/ebaymotors/ws/e...tem=7944219122&category=33554&sspagename=WDVW
You may have to play with the fuel pressure a little. It may be quite rich at low rpms.
67efivert
348
lincolnton nc
Dec 29, 2004
  • Dec 29, 2004
the 4.0l ranger exporler has 19lb injectors and they are red or black top
the ohv motor that is the sohc has 24 i think hope this helps
P
Pro-Hawk
971
West Texas
Dec 29, 2004
  • Dec 29, 2004
This is where I wonder if this will work. I always heard when going to the next size injector like a 19lb on a N/A 2.3L you need the matched MAF.Anyways, will the SD just work right off the bat when he drops in the 19's
PS. you can usualy find a set of 8 19lb high pendence ( how ever its spelled lol) off a 5.0 on ebay thats pretty new. Just turn around and sell the other 4 to someone else doing the same thing as you are.
R
Fox Foxbody Notchback Coupe 1979
  • robrouck
  • Apr 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 20, 2026
slow84lx
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
Old guy new to Forum.
  • 08shelby GT500
  • Jun 15, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 15, 2026
LILCBRA
