Injector swap
  • Thread starter Thread starter Bam1
  • Start date Start date Apr 6, 2005
Bam1
43
Dayton Ohio
Apr 6, 2005
  • Apr 6, 2005
I was wondering how long it takes to change out injectors on a 5.0
D
Daggar
3,902
  • Apr 8, 2005
Maybe 2 hours if you've never done it before and you gotta fight with the upper plenum cover to get it off. Replace the plenum gasket and retorque it correctly.
P
pconway
72
wtby, ct
Apr 8, 2005
  • Apr 8, 2005
im not trying to take over a thread but is thee a certain way to put them in??
like i think i heard someone say their injectors werent set in right.
D
Daggar
3,902
  • Apr 8, 2005
Just lube em up with silicon and make sure they're seated all the way down into their fittings when you put on and bolt the fuel rails back down. If after you hook up the connectors, you turn them towards the fuel rail then you shouldn't have any clearance problems. At least I've not seen any on any intakes I've been part of putting back together and that includes my Kenne Bell.
M
Mattys5Oh
216
Western, Mass
Apr 8, 2005
  • Apr 8, 2005
Yeah 2 hours seems a good estimate. make sure you have all new O-rings and that the injectors are pushed in well enough so the fuel rails bolt up perfectly.
Fuel Fuel injector cleaner?
  • Creomod
  • May 29, 2026
Fox 5.0 Mustang Tech May 30, 2026
evintho
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
A
Injector question
  • arrickburke
  • Sep 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 19, 2026
arrickburke
A
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
