  • SN95 4.6L Mustang Tech
INJECTORS
  • Thread starter Thread starter sweet tooth
  • Start date Start date Dec 9, 2009
sweet tooth
154
  • Dec 9, 2009
does anybody now what the max duty cycle is on 19lb injectors on 2002 4.6,what my fuel pressure is or should be?
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Dec 9, 2009
  • Dec 9, 2009
19's can handle almost 300rwhp, stock fuel pressure is usually 39lbs with the vacuum line off..........
sweet tooth
154
  • Dec 9, 2009
how do you do a fuel pressure test and is that the max duty on my 19lbs on a 2v.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 9, 2009
  • Dec 9, 2009
Injector duty cycle should not exceed 85%.
The stock Mustang GT fuel pressure should be 40 PSI (manifold referenced). The fuel pressure should not vary by more than a couple of PSI from idle to WOT.
Note if measured at the fuel rails, this is NOT manifold referenced. At idle, the pressure will be less by the intake vacuum.
sweet tooth
154
  • Dec 9, 2009
hey thnks.
BurningRubber
1,865
24
58
Dec 9, 2009
  • Dec 9, 2009
An '02 should have 21lb injectors, not 19's.
The 19's are yellowish/orangeish.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 9, 2009
  • Dec 9, 2009
Threads merged. Only one is necessary, please.
sweet tooth
154
  • Dec 9, 2009
o really my are pink i didnt know that because car is tune 4 19lbs.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 9, 2009
  • Dec 9, 2009
This is a technical forum with a lot of very knowledgeable ppl monitoring. Instead of asking narrowly focused questions why not take the time to explain to everyone what the problem is and what you are trying to do?
For the record, no one knows what your injector max duty cycle is because it depends upon the tune and the other mods done to YOUR car.
IMO the easiest way to measure fuel pressure is to use an ODB2 scanner and ask the PCM what the fuel pressure is. The PCM will report the manifold referenced pressure which is what really matters anyway.
The yellow top injectors are #19's. The red/pink top injectors are #21's. If your tune is for #19's, then the AF will be rich all of the time. However, the PCM will adjust for the difference by subtracting fuel from the long term fuel trim. Again this can be seen by using an ODB2 scanner. Look for negative values.
Suggest having a talk with your tuner.
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
