  • SN95 4.6L Mustang Tech
inner tierod
  • Thread starter Thread starter 2000fordstanggt
  • Start date Start date Apr 9, 2007
1 of 2 Next Last
2000fordstanggt
404
Westland, MI
Apr 9, 2007
  • Apr 9, 2007
when i bought my new tires i was told that my drivers side inner tierod was bad. so i went to murrays and bought a new one. after searching i only could find related posted about the tierod ends, which i did this past summer. so could someone please point me in the right direction. -thanks
BlackenedSVT
1,841
New Jersey
Apr 9, 2007
  • Apr 9, 2007
Well never done one on a mustang before, but im sure all you do is remove the boot, screw in the inner tierod, lock it up and install a new boot. I can't imagine it being much harder.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Apr 9, 2007
  • Apr 9, 2007
I thought tires were usually affected by the outer tie rods more so than the inners. I've also heard that the inners are a real PITA and you might as well buy a new rack. If there is play in your wheel and tire when the car is off the ground, that should be your outer tie rod i would think.
joshheat25
871
Delaware
Apr 9, 2007
  • Apr 9, 2007
Yea I also am changing my tie rods.. and I am glad that I am doing inners and outers while I have it apart.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Apr 9, 2007
  • Apr 9, 2007
inners are easy if you have the right tools. without the tool they are a PITA. any side to side play in your wheels can be either the inner or the outer. the outers are VERY easy to replace. i would suggest asking a alignment tech at a local shop if he does any side work. i'm sure they will be happy to install them for you for a little cash!
tires are affected by ANY loose or worn front suspension and steering parts
joshheat25
871
Delaware
Apr 10, 2007
  • Apr 10, 2007
What are the Right tools for the Inners? do I need anything out of the ordinary?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 10, 2007
  • Apr 10, 2007
yes you need an inner tie rod tool for rack and pinions. its about $100 from a Snap-On, MATCO, MAC tool truck. also i think ford holds the inner tierods in with a rivet, that you need to pull out. if you dont get it all out and thread the inner off it will ruin your rack.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Apr 10, 2007
  • Apr 10, 2007
i found out the hard way about that damn rivet! i ruined a rack on a taurus when i first started doing alignments about 3 years ago. i know the explorers dont have a rivet (did one of those inners today) i'm not sure if mustangs do or not since i have never replaced an inner on a newer one.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 10, 2007
  • Apr 10, 2007
when i did alignments i woudl try to find something else wrong so they would sell a rack and not the inner. doing a rack was a lot easier and paid better.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Apr 11, 2007
#10
  • Apr 11, 2007
  • #10
I actually changed mine with ease. I used a crescent wrench and a vice grip, and broke them free that way. after you remove the boot, slide it toward the outer tie rod end, and you'll have access to the inner tie rod "nut" where you can place crescent wrench. then clam the vice grip somewhere, and give it hell.
2000fordstanggt
404
Westland, MI
Apr 11, 2007
#11
  • Apr 11, 2007
  • #11
thanks, i think im going to be doing it this saturday. ill be sure to let everyone know how it went.
joshheat25
871
Delaware
Apr 11, 2007
#12
  • Apr 11, 2007
  • #12
yea thanx I really don't want to go spend 100 dollars on the tool!
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 11, 2007
#13
  • Apr 11, 2007
  • #13
there is no rivet.. but they do use threadlocker, and you DON'T need the inner tie rod tool for mustang inners, you can get to the wrench flats since the rack is right up front.
I don't know where you guys find these fords with rivets.. I have done many inners on taurus from early 90's through current models and have never seen a rivet ??????? What year were these fords
I was thinking of asking on the PTS message board to see if any other ford techs have seen rivets on a inner tie rod but since thats a Ford internal message board and my full name and dealer info goes on every post there I don't want them thinking I am smoking rock.
The worse inner tie rod on a ford is the escape, there is no wrench flats at all it's IMPOSSIBLE to get out.
So if you independant guys get a escape with a inner tie rod thats bad just sell a rack.
W
w.neurauter
98
#14
  • Apr 11, 2007
  • #14
I had to do mine a few months ago, it was a breeze and no rivets at all like everyone else said.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Apr 11, 2007
#15
  • Apr 11, 2007
  • #15
it may have been another car i was thinking about. i know some of the early 80s cars had something thru the inners. nothing can be as bad as the chrysler tie rods that you have to take all the intake stuff apart to get to.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 11, 2007
#16
  • Apr 11, 2007
  • #16
the rivet was on an aerostar.
Mike97gt
it doe snot
10,633
Apr 11, 2007
#17
  • Apr 11, 2007
  • #17
Aerostars suck, we don't see any of those around here anymore.. Thank god because that thing was a hunk of trash
chrysler FTL I hate modern mopar stuff and since I am a ford tech I never see those. I did work at a Ford/Dodge dealer at one point but I told them I had severe allergic reactions to chrysler products.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 11, 2007
#18
  • Apr 11, 2007
  • #18
id say that was one of the 10 worst vehicles ford ever made. doing alignments that involve caster or camber adjustments was unnecessarily hard.
alas, i no longer work as a tech, but work at a lincoln/mercury dealer in the parts dept.
Mike97gt
it doe snot
10,633
Apr 11, 2007
#19
  • Apr 11, 2007
  • #19
congrats on escaping the trade.. soon you should try to escape from the auto business.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 11, 2007
#20
  • Apr 11, 2007
  • #20
i know what you mean. i still have my matco double bay box and all my matco and snapon tools. i figure having a 40k tool bill when im 23 isnt bad. ill pay that off and then be the envy on my neighbourhood for the rest of my life.
so now the new challenge is learning all the ford parts computers. i already have buddies wantign me to get them BOSS 290 parts.
1 of 2 Next Last
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
