Install Problems Yesterday
  • Thread starter Thread starter townethug
  • Start date Start date May 30, 2006
T
townethug
20+ Year Stangneter
May 17, 2004
124
May 30, 2006
  • May 30, 2006
So yesterday I started my install of upper and lower intake manifold and am now faced with a couple of questions. The first and most important question is one of the bolts used to mount the lower to the heads broke off inside the head. After spending several hours trying to remove it, it has become blaringly clear that the head is going to have to come off for either replacement or to take it to a machine shop. Does anyone have any experiences similiar to this? What worked best for you and where can I get the exact head replacement so I can replace just the one side?
Now, as I was removing the upper, I noticed a number of differences between my HO upper and the cobra upper I bought. First thing I saw was on my HO upper there are two vacuume lines that connect near the throttle body and on the cobra there is only one. So what happens to the remaining vacuume hose? Also I am guessing I will need new bolts to connect the throttle body to the manifold because the existing ones are very rusted and dont look like they would work anyway. Another thing I noticed was that under the upper there is a vacuume hose that connects on the front of my HO upper but on the cobra it connects on the back side. I guess what I am getting at is, are there any documents for swapping from my upper to the cobra since they have different vacuume setups.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 30, 2006
  • May 30, 2006
Vacuum lines are usually not critical to their placement on 5.0 Mustangs. Whatever fits, connect it. Plug what you don't need and use the vacuum tree if you need to connect something and don't have a vacuum source to connect it to.
The HO upper intake that comes on Mustangs is not compatible with a Cobra lower. The arrangement of the ports is very different. The stock HO upper has all of the ports in a straight line and the Cobra lower has them in a zigzag pattern.
T
townethug
20+ Year Stangneter
May 17, 2004
124
May 30, 2006
  • May 30, 2006
I knew that the lower wouldnt fit I was just concerned when i saw that the vacuume lines where not the same.
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
