Installing New Flywheel Dowels
  • Thread starter Thread starter 92GreenGT
  • Start date Start date Jun 25, 2005
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Jun 25, 2005
  • Jun 25, 2005
Bought a new flywheel and I have to install the dowels over to the new flywheel, I know what holes the dowels go in and all that but whats the best way to put em in, from the bottom or top? I didnt want to get to rough with it before I asked. Thanks
At1Maverick69
220
San Leandro, Cali
Jun 25, 2005
  • Jun 25, 2005
put em on from the clutch side ( at least that's how i did it). make sure u use a dead blow hammer, so u dont dent or warp ur flywheel. good luck!
D
Daggar
3,902
  • Jun 25, 2005
a modest amount of your favorite high heat sealant will help lube them up for a easy install and once cured will basically serve no purpose at all. hehe. Just helps them slide in a bit easier.
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Jun 25, 2005
  • Jun 25, 2005
I will go try the clutch side with some lube. Thanks
Dave
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 25, 2005
  • Jun 25, 2005
I have did this to a couple flywheels. I just use a hammer and tap them in. Once you get them started straight they will just hammer the rest of the way down in. The trick is getting them started straight.
They can only go in from the clutch side anyways. They have "bottoms" where the dowels will stop at so you can't stick them in from the engine side of the flywheel anyways.
Good Luck and be patient
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Jun 25, 2005
  • Jun 25, 2005
Dont worry, I have a BFH to take care of them if they give me trouble
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
Jun 25, 2005
  • Jun 25, 2005
As far as which hole line up the pressure plate hole with the threaded holes on the flywheel and put the dowels in the center unthreaded hole after removing the plate.
Jamie
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Jun 25, 2005
  • Jun 25, 2005
Also, when I did my Fidanza they specifically tell you to use permanent loc-tite in the dowel holes on the flywheel.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 25, 2005
  • Jun 25, 2005
That probably isn't a bad idea...
Otherwise, when the pressure plate is tightened down it pushes against the flywheel dowel pins where it gets tapered down so unless your pressure plate backs out (bolts get loose) the flywheel dowel pins have no chance at all to come out. Mine have always been a very tight fit anyways
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
