installing roller tip rockers
  • Thread starter Thread starter shttygtstang
  • Start date Start date Nov 2, 2004
shttygtstang
978
  • Nov 2, 2004
im installing my rrs and the nut that goes on the stud is a pita to get to with my socket once i start tightening it it just slips off its like the socket doesnt fit inside the rr is the somthing im doing wrong or a speical thin wall socket i need i very confused it been a long day
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 3, 2004
  • Nov 3, 2004
What roller rockers you using?
I just put a socket on a ratchet and tightened it down with that...I had no slipping problems at all...it was right there...nothing in the way...
I used a hex headed socket to tighten down the locking adjusting nut...
TrickStang37
292
  • Nov 3, 2004
the hex head of the lock nut shouldnt go down far enough where the socket will hit the roller rocker. are you using regular nuts on there??
shttygtstang
978
  • Nov 3, 2004
the nuts are the ones that came with the kit
my socket its (17 mm)wont fit inside were the felcrom goes so once i get it started i cant reach it after that
here they are
http://cgi.ebay.com/ebaymotors/ws/e...ry=33624&item=7930667871&rd=1&ssPageName=WDVW
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 3, 2004
  • Nov 3, 2004
F-U-L-C-R-U-M
17mm? That's HUGE compared to any nut size I've seen associated with roller rockers for these engines. Oh, and they've all been US standard sizes, not metric. Not that that helps any - but at least you know how to spell felcrom now.
Rick 91GT
Mustang Master
95
99
PA
Nov 3, 2004
  • Nov 3, 2004
For installation you put the rocker over the stud, then install the pivot ball (round portion down, against the rocker) then install the nut.
A standard socket should fit with no issues, I use a 3/8" drive with no problems. You could try a 1/4" drive they are generally smaller. Most are 9/16"-5/8" sockets.
04sleeper
2,674
14
89
Dallas, TX
Nov 3, 2004
  • Nov 3, 2004
So you are building a 331 Blown/Stroker motor with Edelbrock heads and Victor intake and you bought $69.00 rockers? Why would you not get something more popular like a full roller rocker?
shttygtstang
978
  • Nov 3, 2004
im using a 3/8 drive but a 5/8 is to small im gunna call theese guys see wuts up
oh thanks mr yount dont wana be caught empty handed not knowing how to spell that
im not building a 331 those plans fell through and i went with theese roller tip rockers cause im broke and thats all i need to finish this damn thing
shttygtstang
978
  • Nov 3, 2004
http://www.catpep.com/installation/rockerarmandgirdle/steelrokerarm.htm take alook at there site donst tell much am i missing somthing
shttygtstang
978
#10
  • Nov 3, 2004
  • #10
what would happen if i used grade 8 nuts from home depot with tread lock
On3 Performance Install Tips
  • flstang65
  • Dec 15, 2019
12K
1996 - 2004 SN95 Mustang -General/Talk- Mar 17, 2023
atomicfox236
A
D
2012 EPAS Power Steering Unit Replacement Tips & Tricks
  • DC_Dave
  • Nov 11, 2018
10K
2005 - 2014 S-197 Mustang -General/Talk- Apr 30, 2020
scott mckay
Old H/c/i Installation Explanation And Pics
  • FastDriver
  • Jan 26, 2018
2K
Fox 5.0 Mustang Tech Jan 27, 2018
FastDriver
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
'67 Mustang 289 V8 Loose Rocker Arm Polylock Nuts Wtf?
  • cjstang6791
  • Jul 18, 2016
5K
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2016
cjstang6791
