instrument cluster problems
  • Thread starter Thread starter Lawbreaker5.0
  • Start date Start date Dec 8, 2009
L
Lawbreaker5.0
543
Texas
Dec 8, 2009
  • Dec 8, 2009
Alright i know this is 5.0 tech but i just bought a 93 4 cyl and i'm about to drop a 5.0 so i think it applies here. Also i think there are good knowledgable people in this section.
The main problem i see so far is there are no instrument lights that come on when the key is turned besides the batt light
Prob a fuse but i need other suggestions
When the key is turned to on and the car is off, the rpm jumps up to 900 rpms and stays there, kinda wierd since its not running. I'm not positive if the speedometer works because i didn't drive it home since the clutch was gone and i don't how to shift it without a clutch, so my friend drove it for me.
And the dimmer switch is supposedly busted. i found an extra one in the trunk so it makes me think its not the switch.
thanks guys
edit:
so i checked fuses and found that the instrument cluster fuse was removed. i realized why when the lights wouln't turn off. i assume it the dimmer switch becuase it was frozen on the part where you click your lights on. i broke it loose and it did not dim the instrument lights.
does anyone know how many fuses should have power when the key is off? there are about 4 that have power when the key is out and off, if i remember correctly there is usually two that have power. And when you turn the key to on the rpm jumps to 900, then falls to 400 shortly after.
F
Foxlover
11
DeKalb, Ill
Dec 8, 2009
  • Dec 8, 2009
Is the wires in the plugs that plug into the cluster in the right spot. You can probably find where they are supposed to be online. But I rearranged all mine using a Chilton's manual.
L
Lawbreaker5.0
543
Texas
Dec 9, 2009
  • Dec 9, 2009
i haven't taken the dash apart yet, so i wouldn't know how the wires are behind there.
i guess i'll find out soon. i have to change the dimmer switch anyway
Interior and Upholstery 1993 Instrument Cluster cover
  • KevinV
  • Jul 2, 2026
Fox 5.0 Mustang Tech Jul 3, 2026
AeroCoupe
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
  • Mindseye007
  • Aug 16, 2026
Mindseye007
