iol pressure
  • Thread starter Thread starter 86mustang5.oh
  • Start date Start date Aug 5, 2005
86mustang5.oh
125
battle creek mi.
Aug 5, 2005
  • Aug 5, 2005
oil pressure is on the N or normal and there is a slight nock to my engine any ideas
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Aug 5, 2005
  • Aug 5, 2005
I have an Idea...sorry to sound blunt, but you may want to start looking for a new or rebuilt short block. Good time for a H/C/I upgrade eh??. And while your at it get a real oil pressure gauge on there..stocker is a joke, as I have found out.
86mustang5.oh
125
battle creek mi.
Aug 5, 2005
  • Aug 5, 2005
i work at mcdonalds i dont have money for any thing new i just need to fix this shi t
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Aug 5, 2005
  • Aug 5, 2005
Fixing a knock caused by low oil pressure is a serious issue..not something you can ignore. My approach would be to put a real gauge on the car, and if really is low the engine will have to be opened up. Sorry for the bad news..
86mustang5.oh
125
battle creek mi.
Aug 5, 2005
  • Aug 5, 2005
do you think it could be a rocker and i cheaked my oil and i have about a 1/4 in over the full line i think i should drain some
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Aug 5, 2005
  • Aug 5, 2005
Don't know..you have to find out the "true" oil pressure situation..if it's low then you need to address the problem. You stated your pressure is almost nil on the gauge, and that you have a knock. Those two combined are not good issues..you can't guess, you need to know the facts of what's really going on.
Euphoric306
905
  • Aug 5, 2005
just cuz u have oil doesnt mean the engines ok... get a mechanical gauge, somehow.. and hook it up to where the oil sending unit is....
if you're running with low oil pressure and you hear a knock, chances are you threw a rod bearing.. which means rolling in new bearings, or worse, depending on how loww ur pressure is and how long you've ran with it that low.
could cost you new crankshaft, new rods, who knows...
DONT start your engine again until u get a mechanical oil pressure gauge on it, pressure should be around 45-60psi at 2000rpm, if any lower than 40, my suggestion is pulling the engine and checking out your bottom end
i too am sorry for the bad news but low oil pressure is no joke
if you're lucky, it could be a lifter not getting enough oil to it, which probably didnt cause any damage to anything... yet, but as stated, dont run your engine, unless you've got major $$$ to put into all new internals
HISSIN50
34
129
Aug 5, 2005
  • Aug 5, 2005
the parts store should have mech oil pressure gauges for around 10 bucks. Money well spent. I agree about getting one and trying it before you drive the car again.
We are not trying to get you to spend money, but 10 bucks could save you a lot more in rebuild costs.
Good luck bud.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
C
Looking for electrical schematic 1986 GT
  • CMT3
  • Sep 21, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 23, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
