Is this aligned correctly?
  • Thread starter Thread starter sparx
  • Start date Start date Jan 11, 2010
sparx
369
  • Jan 11, 2010
Since this is my first engine (partial build) I just want to be sure this is correct before I continue. I want "Murphy's Law" to stay away from my engine.
sparx
<a href="http://photobucket.com" target="_blank"><img src="http://img.photobucket.com/albums/v281/sparx21/IMG_0039.jpg" border="0" alt="Photobucket"></a>
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jan 11, 2010
  • Jan 11, 2010
You have correctly assembled the entire timing set and pump eccentric.
68stang351
850
9
39
Savoy TX
Jan 11, 2010
  • Jan 11, 2010
Yep, looks right to me.
95Vert383AOD
1,133
34
69
New Bedford, MA
Jan 11, 2010
  • Jan 11, 2010
I love doing SBF timing sets!!!! I just hate removing all the crap necessary to get to that point. But that looks perfect!!!
woodsnake
1,352
15
69
Hicksville, NY
Jan 11, 2010
  • Jan 11, 2010
Did you put some loc-tite on the bolt that holds the cover in place?(The center bolt that holds the camshaft dowel pin in place) I forgot just once, and had to pull it all the way apart again......
rbohm
6,698
550
204
tucson,az
Jan 11, 2010
  • Jan 11, 2010
looks good to go.
jcode68
892
Massachussetts
Jan 11, 2010
  • Jan 11, 2010
As others have said, everything looks good, congrats. I notice you are using the 1 piece fuel pump eccentric. If you are not already aware, there are 2 different eccentrics (1 piece and 2 piece) and they are not universally compatible with the timing covers. The 1 piece is slightly thicker and causes an interference with the timing cover (I believe the early style cover is not compatible). Do a dry fit of your timing cover and turn the engine over by hand a few rotations to make sure you don't have an interference. Remove the cover and if you have rubbing, you will be able to tell. It's much easier to find this out now before putting in the car and running etc.
65-Fstbk
316
26
49
Vancouver, B.C. Canada
Jan 12, 2010
  • Jan 12, 2010
I will be building my engine as well but it will be my first.
Isn't there usually 3 key slots on the crank gear? One for 4 degrees advance, one for neutral and one for 4 degrees retarded? I only see one key slot. What am I missing (besides experience)?
rbohm
6,698
550
204
tucson,az
Jan 12, 2010
  • Jan 12, 2010
stock replacement timing sets only have one slot in the crank gear. it is the aftermarket ones that have multiple key ways.
sparx
369
#10
  • Jan 12, 2010
  • #10
Hey thanks all, I feel better now!
Yes I did lock tight the eccentric screw as well as the two screw behind that hold the cam plate in place.
I did check for timing cover clearance, the gear had to be cut down a touch by my machinist to allow the proper clearance, good call jcode.
I am the slowest Mustang rebuilder for sure, and ask lots of elemetary questions but, I have caught many potential errors just in the last few weeks being extra careful.
Thanks guys for all the assistance!
Once I get the timing cover and water pump on I can get to adjusting the valves and then installing the intake.
sparx
oz
1,079
10
58
Plymouth, MI
Jan 12, 2010
#11
  • Jan 12, 2010
  • #11
Just pick up a copy of the book 'Rebuilding Small Block Fords' (or something like that) and follow it and you'll be fine.
sparx
369
#12
  • Jan 12, 2010
  • #12
I got that book, and have been reading it.
I have two books actually and that is one of them.
My machinist has been very helpful also.
sparx
I
Exorcising a '78 Mach I
  • IICrew
  • Aug 10, 2020
  • 2 3
10K
1974 - 1978 Mustang II Talk & Tech Sep 26, 2022
Adieu
Brake-hose-to-drum Fit Issue.
  • 70mstang
  • Mar 2, 2018
Classic Mustang Specific Tech Mar 2, 2018
70mstang
R
Engine 1992 Mustang Hesitation/Cutting-Out
  • RTW0223
  • May 2, 2018
14K
Fox 5.0 Mustang Tech May 26, 2025
C
Engine why is this oil leak happening? (pic)
  • craig3x
  • Feb 2, 2013
2K
Classic Mustang Specific Tech Feb 28, 2013
SHEDRED
  • Locked
Expired Stock 75 amp alternator
  • mikestang63
  • Nov 17, 2012
  • Engine and Power Adder
Engine and Power Adder Nov 17, 2012
mikestang63
