It's a 67 and I put a 2008 shelby gt500 in it and the engine is too big to fit the A/C in, any tips?
67_Ellie
12
texas
I bought a 67 Mustang and have it ready to send to paint besides the A/C, and I live in Tx so driving without A/C will most likely kill you can anyone help?
  • Sponsors(?)
WORTH
2,103
29
98
67
Cape Cod, Ma.
68.69.48.22
What is your clearance issue? what hits where?? Is the engine bolted up and useable with the exception of the A/C? If so can you take a few pictures from different angles?
67_Ellie
12
texas
Yes, it's ready to use besides the PCM having to be connected to the instrument cluster, when I am at work tomorrow I will take more detailed pictures it is mainly hitting on the supercharger and the engine itself. I am trying to find a way to route it a different way through the car instead of stuffing it in the dashboard.
67_Ellie
12
texas
The condenser and the housing are hitting, and I said the wrong thing it's just hitting on the engine.
WORTH
2,103
29
98
67
Cape Cod, Ma.
68.69.48.22
I guessing you are using the wrong terms, the condenser is the cooler that looks like a radiator and it's mounted in front of the radiator. You need to have someone tell you what part is the problem and what part of the engine it is hitting, then I can help. ALso a picture or 2 of where they are contacting would be good. You gave me 2 pix of the back of the engine near the firewall.
67_Ellie
12
texas
Sorry, just a small mix up on the terms and we don't have the a/c just the measurements and i'm trying to find one that will fit.
Thread starter Similar threads Forum Replies Date
P Putting in cams with scarred bearings- A lost cause? SN95 4.6L Mustang Tech 8
2Blue2 Help I want to put this T5 in our Cobra II 1974 - 1978 Mustang II Talk & Tech 73
7991LXnSHO Want to put EFI on a 6 Cyl. What System to get? Digital Self-tuning Forum 5
Mstng93SSP Putting my engine together 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 95
Old Catman Questions - Putting a 93 5.0 in a 66 1965 - 1973 Classic Mustangs -General/Talk- 2
B Fox Just picked up a sick set of cobra rims the rears are 17x9 and the fronts are 17x8 whats the biggest set of tires i can put on there guys 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Jason Roberts O2 Simulators put on a 1994 GT 5.0 do they hurt the car or are they useful even though the 94 GT only had 2 O2 sensors and they were before the cats 1994 - 1995 Specific Tech 3
H Anyone have any info on putting a 86 svo doghouse on a 93 convertible? The Welcome Wagon 0
H Anyone ever heard of putting an entire SVO front doghouse on a 93 convertible? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 56
MrPerfect2 Will steeper gears put more stress on AOD and a stock 5.0 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 34
90sickfox Decided- I'm Putting Godzilla in my Ecoboost 2015+ (S550) Mustang -General/Talk 0
J What should I put in a 1998 GT roller? SN95 4.6L Mustang Tech 1
C Which speedo gears to put after a 3.73 gears on a 98 GT? SN95 4.6L Mustang Tech 5
Hoytster Progress Thread Darn Stock Block Problems - Putting together the pieces Fox 5.0 Mustang Tech 66
M Need help putting big valves in 65 289 heads Classic Mustang Specific Tech 0
R 5Volts reference putting out 12 volts with key on 18 volts with car on(overcharge) 1996 - 2004 SN95 Mustang -General/Talk- 3
M Questions about putting a 4.6 into a 1966 1965 - 1973 Classic Mustangs -General/Talk- 28
C New guy...reviving this little guy.built it about 10 yrs ago,had to put it away after just a couple Hundred miles,sitting ever since Fox 5.0 Mustang Tech 26
Wayne Waldrep Car put me down......again. What now? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 29
D Can 2006 convertible top be put up manually? 2005 - 2009 Specific Tech 3
0 dies at idol when put in park 1996 - 2004 SN95 Mustang -General/Talk- 1
S Having issues with my 97 cobra mustang. Tried to put a tune on it with a diablo sport in-tuner. 1996 - 2004 SN95 Mustang -General/Talk- 0
K Hello I am brand new to this site. I have a 2002 v6 stnd tran. and I have a street 302 +,060 with a c4 that I want to put into the car. How hard isit 1996 - 2004 SN95 Mustang -General/Talk- 1
1 Just bought 1983 Mustang GT dies when put in nuetral Fox 5.0 Mustang Tech 4
P 97 mustang gt an I put a 75mm throttle body a bigger throttle body housing an now my is running like crap 1996 - 2004 SN95 Mustang -General/Talk- 3
K Hard time putting can in to park 1996 - 2004 SN95 Mustang -General/Talk- 0
94GT/Cobra Engine 1997 gt 2v.. Putting heads back on after getting them from machine shop?? SN95 4.6L Mustang Tech 0
F stalling, when putting in gear 1994 - 1995 Specific Tech 0
C Engine 88 mustang gt stalls when put into gear Fox 5.0 Mustang Tech 28
1 putting a 1995 T5 to a 1985 5.0 engine. The Welcome Wagon 1
6 Engine 1967 289 T5 Swap NO Crank after putting everything back in. Classic Mustang Specific Tech 17
T 2018-dealers putting in 8qts and not 10 on gt's Beware!! 2015+ Specific Tech 0
darryl paarman how many square feet to put in sound deadenr 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
James V Interior and Upholstery Anyone else have a hard time putting on steering column cover? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
S 99 mustang had the gas tank drop out broke strap there where you put the gas in leaks underneath when I put gas in, there are two other hoses near it 1996 - 2004 SN95 Mustang -General/Talk- 0
L Putting together a 408 stroker for a 94-95 sn95 car. Need some input. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
K Won’t stay idled after I put gas in it 1996 - 2004 SN95 Mustang -General/Talk- 4
killer5.0 Paint and Body Plan to put the car on rotisserie next winter. Can i leave interior and glass in the car? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Vi1414 93 foxbody. Can i put 18 inch in rear and 17s infront? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
BiminiBlue92LX5Ohhh Dealership May Have Put 6 Qts In My 92 Lx 5.0 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 40
T I Need Help Putting Tragically Modded Car Back Together 1996 - 2004 SN95 Mustang -General/Talk- 5
L Need Help Deciding Type Of Cam To Put In 65 Stang 1965 - 1973 Classic Mustangs -General/Talk- 6
W Putting A 88 5.0 Motor In A 86 4 Cylinder Car.. Computer And Wiring Harness Fox 5.0 Mustang Tech 12
B Drivetrain Aod Transmission Noise When Putting Into Drive Fox 5.0 Mustang Tech 3
fat_fox What A Mess...someone Save Me From Putting A Carb On My Motor 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
deathb4dismount Best Thing I Ever Put In The Mustang 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 55
C Putting Togeather 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
billison Putting The Engine Harness Back Together Fox 5.0 Mustang Tech 7
James V Fox Has Anyone Put A 4 Point Roll Cage In Their Fox?? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
The Green GT Getting Ready To Put The Engine Back Together. Quick Question. 1994 - 1995 Specific Tech 6
