  • SN95 4.6L Mustang Tech
kb for GT
  • Thread starter Thread starter 04Cobra
  • Start date Start date Apr 25, 2004
04Cobra
72
CA
Apr 25, 2004
  • Apr 25, 2004
if I install kb on bone stock GT what other things should I change it so no problems? do I need to change the exhaust system?
neoclasiccl
3,043
Help I can't see !!!!!!
Apr 25, 2004
  • Apr 25, 2004
I would honestly ditch the Heat exchanger (if you get the 9psi kit). The inlet temps get out of control on the GT Kenne Bell. If you go that route get a good H/E with fans. You can have an 03 Cobra H/E installed with some fabbing and that should help with heat soak.
Saleen201
1,271
Doha, Qatar
Apr 25, 2004
  • Apr 25, 2004
umm, pardon my ignorance, but what is a "heat exchanger"?
neoclasiccl
3,043
Apr 25, 2004
  • Apr 25, 2004
Under the Kenne Bell there is an intercooler that cools the inlet temps going into the motor. The heat exchanger is like a radiator and uses coolant that flows into the intercooler and it is mounted in the front bumper like a radiator. The air cools coolant and then it flows under the blower.
Saleen201
1,271
Doha, Qatar
Apr 25, 2004
  • Apr 25, 2004
I keep hearing how great the KB blower set ups are, i assume this is the only "bad" part to the blower? How much modification is needed to get the 03 cobra H/E to work with the KB blower kit?
And thanks for the expanation, i didnt know it was called a Heat Exchanger
-Mike
Caballo Salvaje
47
KY
Apr 25, 2004
  • Apr 25, 2004
Try amazonracing.com, they have one that modifies the cobra set up(larger exchanger and fans) and would probably wouldn't cost much more. That's what I think I will do so I can run 11 pounds of boost with a custom tune.
krly79
464
VA Beach & So Illinois
Apr 25, 2004
  • Apr 25, 2004
Kenne Bell
MT1083
1,033
Charlotte, NC
Apr 26, 2004
  • Apr 26, 2004
Mine runs fine pretty much stock. Although I don't do any racing, so I don't really give mine the chance to heat up very much. I just have my fun rides here and there. I will probably start beefing up parts as soon as I get money. Next on my list are 31 spline axles and a new differential.
Screwed2V
1,255
Misery
Apr 26, 2004
  • Apr 26, 2004
-Mike
www.gordsfordperformance.com makes one with brackets on it that will bolt right up to a GT. I don't think it's listed on his site but I've spoken to him about it recently.
D
DJT03GT
187
New Jersey
Apr 26, 2004
#10
  • Apr 26, 2004
  • #10
neoclassiccl are you saying get the 6lb non intercooled kit from KB and buy a cobra H/E? Then possibly swap to a smaller pulley? Possibly saving a few hundred bucks along the way.
MT1083
1,033
Charlotte, NC
Apr 26, 2004
#11
  • Apr 26, 2004
  • #11
I think he means just replace the h/e itself but still have the 9# intercooled kit.
neoclasiccl
3,043
Apr 26, 2004
#12
  • Apr 26, 2004
  • #12
I would order the 9lb kit but tell them to deduct the HE and order the gords unit.
stallion98gt
1,802
Los Angeles, CA
Apr 26, 2004
#13
  • Apr 26, 2004
  • #13
what about the warranty ?
D
DJT03GT
187
New Jersey
Apr 26, 2004
#14
  • Apr 26, 2004
  • #14
thanks neoclassiccl
neoclasiccl
3,043
Apr 26, 2004
#15
  • Apr 26, 2004
  • #15
Not sure on the warranty but I have talked to Tim at T&J's and even with the gords unit the KB GT kit gets hot.
neoclasiccl
3,043
Apr 26, 2004
#16
  • Apr 26, 2004
  • #16
DJT03GT said:
thanks neoclassiccl
your welcome
kirkyg
3,568
Beaumont, TX
Apr 26, 2004
#17
  • Apr 26, 2004
  • #17
What kind of numbers are you putting out. I see your pushing upwards of 17 psi now. Have you gotten any runs in yet? I'm surprised that noone else has really complained about extra heat from KB blowers. Only thing i heard in the past is how the intercooler works very well to reduce heat
kirkyg
neoclasiccl
3,043
Apr 26, 2004
#18
  • Apr 26, 2004
  • #18
kirkyg
The car hit 548 rwhp with only 13 deg timing (we are going with 17 or 18deg) but Tim had to lift at 6000rpm since the MAF pegged. He is going to tune the car to 620-640 rwhp or so but he said the car wants to do 650+
As far as the intercooler it's the one of the 03 cobra and Tim said the inlet temps were awful with their unit. If you go with the 9psi kit tell them to subtract the intercooler and get a gords unit.
kirkyg
3,568
Beaumont, TX
Apr 26, 2004
#19
  • Apr 26, 2004
  • #19
WOWWWWW thats some serious power
So your saying get the non-intercooled kit and this other unit will replace the entire intercooler from KB? I really guess i need to understand how the intercooler works.
kirkyg
neoclasiccl
3,043
Apr 26, 2004
#20
  • Apr 26, 2004
  • #20
kirkyg
No get the intercooled kit without the H/E since you will need the pumps reservour and stuff.
Yeah this car is going to be scary
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
M
What changes need to be made to the brake system after swapping a V8 rear axel into a V6 1999
  • MARTYMAN
  • Jan 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 22, 2026
Mustang5L5
A
Fuel Capable fuel system for +600hp
  • Avia.tuned
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 24, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
