  • SN95 4.6L Mustang Tech
KB owners in here please
  • Thread starter Thread starter Ibeyorsuperman
  • Start date Start date Mar 27, 2004
1 of 2 Next Last
Ibeyorsuperman
123
Ogden, Ut.
Mar 27, 2004
  • Mar 27, 2004
Has anyone had any problems with the kenne bell intercooler pump? For some reason mine keeps losing its prime. Which means its not cycling through the blower??
any help please
thanks nate
B C
444
Chino, CA
Mar 27, 2004
  • Mar 27, 2004
You must have some air in the system. Send me your email address and I will send you a pdf of the new bleeding procedures that I just received from KB.
Cobra5337
160
Edwardsville, Il
Mar 27, 2004
  • Mar 27, 2004
b c can you shoot some footage of your car or at least get a sound clip???
E
el_kid_1
738
Puerto Rico
Mar 27, 2004
  • Mar 27, 2004
You probably have an air lock because the system was not properly primed. Just loose the hose coming off the pump and let it drain for a few seconds. Then refill the intercooler reservoir. That will alow the air pockect to move out. I know brotha'...priming the IC system is a PITA.
N
Nitrous2V
67
Conway, AR
Mar 27, 2004
  • Mar 27, 2004
I had the same problem with mine after a couple of days of sitting around the pump was no longer primed. I found out I had a very small leak at the plug on top of the union for the hose that runs from the heat exchanger to the intercooler. After snugging the plug up the intercooler pump now stays primed. Any more questions just feel free to ask.
BrightBlue00GT
I am even OLDER than Hawk!
Jun 22, 2000
2,906
Stationed in Korea
Mar 28, 2004
  • Mar 28, 2004
Mine did the same thing on and off for several months. It is a PITA to get it primed right because of the trapped air. That pump makes a wicked noise when it's running dry. Stop immediately when it happens.
You can get some instant relief if you're on the road by cracking the res plug a bit and letting the air escape. Keep the allen wrench in the car all the time.
If the system isn't pressurized, you can also get some instant relief by cracking the upper IC radiator hose and pissing fluid out a bit. Keep a racket and socket in the car for that. Whatever you do, keep that res full AND Teflon Tape that plug to keep air out.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 28, 2004
  • Mar 28, 2004
yeah I have the new supplement for priming also if you need it. shoot me a PM in you still need it.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 28, 2004
  • Mar 28, 2004
Hey BC, is the car back on the road after the accident yet?
BrightBlue00GT
Jun 22, 2000
2,906
Stationed in Korea
Mar 28, 2004
  • Mar 28, 2004
BC, Dan, shoot me a copy of that new priming pdf so I can add it to my documents would ya?
Thanks
MT1083
1,033
Charlotte, NC
Mar 28, 2004
#10
  • Mar 28, 2004
  • #10
I haven't had any problems with mine staying primed. I think I just got lucky. I would recommend checking it frequently though. After hearing about all of your problems, I'm not going to trust mine to stay primed. I have that supplement as well, so if anyone still needs its, let me know.
Y
YellowJacketGT
108
#11
  • Mar 28, 2004
  • #11
14PSI KB on GT built bottom end no heads...
I also had difficulty getting the pump primed. I agree PITA...
Since then I eliminated the small water holding tank and replaced it with a Vortech water holding tank. (already had battery in trunk. Had Vortec w/cooler prior).
I then moved the pump under the heat exchanger. (Pump should be at lowest point).
No priming required.. First turn of the key water came poured out in the holding tank. Gallons of water rather than the small amount in the original tank (BTW- kind of ugly looking blank tank for the GT...)
Can't help but feel the issue is the location of the pump. Inside the wheel well above heat exchange.
Never had any issues when I had the Vortec/cooler. Pump was in a similar location.
I am considering a larger heat exchange unit.
Y
YellowJacketGT
108
#12
  • Mar 28, 2004
  • #12
Picture of Larder cooler tank installed
Picture of larger cooler installed...
http://web.tampabay.rr.com/yellowjacket/Pictures/P2230003.JPG
MT1083
1,033
Charlotte, NC
Mar 28, 2004
#13
  • Mar 28, 2004
  • #13
that link doesn't seem to work for me.
E
el_kid_1
738
Puerto Rico
Mar 28, 2004
#14
  • Mar 28, 2004
  • #14
Same here!
Y
YellowJacketGT
108
#15
  • Mar 28, 2004
  • #15
Picture is embedded in the attached thread...
http://www.corral.net/forums/showthread.php?s=&threadid=430012&perpage=35&pagenumber=4
MT1083
1,033
Charlotte, NC
Mar 29, 2004
#16
  • Mar 29, 2004
  • #16
The only picture on there is an x now.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 29, 2004
#17
  • Mar 29, 2004
  • #17
no pic
Y
YellowJacketGT
108
#18
  • Mar 29, 2004
  • #18
Hosting picture
Can someone host a picture. Seams like my IP only lets me view the pictures.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Mar 29, 2004
#19
  • Mar 29, 2004
  • #19
email it to me.......bulldoze94@aol.com
E
el_kid_1
738
Puerto Rico
Jul 2, 2004
#20
  • Jul 2, 2004
  • #20
Well, it seems like my KB IC pump is starting to give problems. The pump has been on and off for the past two months. The only remedy that seems to work for me is letting the hose from the IC res to the pump piss a bit. After doing that, the pump will just start circulating the fluid again. But after a few days, it will stop working!! This is driving me nuts I see that some of you have had the same problem. What was your solution? By the way, could someone e-mail me the KB write-up on the new priming procedure at el_kid_1@yahoo.com? Thanks.
1 of 2 Next Last
J
Reduced power in 1st and 2nd gear
  • jimted79
  • Feb 25, 2025
SN95 4.6L Mustang Tech Feb 25, 2025
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
  • Gulftown980x
  • Jul 29, 2026
squeak93
