Launching Issues - need some advise.
  • Thread starter Thread starter 90mustangGT
  • Start date Start date Sep 24, 2004
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 24, 2004
  • Sep 24, 2004
Launch under 2000rpm = the car hooks, front come up, rpm's drop and it bogs.
Launch over 2000rpm = Tire spin.
Drop clutch fast = weight tranfers but at low rpm's it bogs, high rpm's tires spin.
Slip clutch = weight does not transfer well, tires spin.
What works best is to start at about 1500rpm and press down the gas as I let off the clutch in a controlled drop but it still tends to bog.
Should I just keep practicing launching or is a certian part hurting me. I am thinking the 275/40R17 Nitto's don't have enough sidewall. Another thing that I can think of is the HPM Megabite JR's being set to the upper hole, which puts them on their 85% level. Maby set them to the 135% level to get the tires to hit the pavment better, although the suspension might start to unload, the weight should be transfered.
Any suggestions, please do.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 24, 2004
  • Sep 24, 2004
I've pulled a 2.08 60 ft. (w/ bolt-ons, full exhaust, and 373's) on 245/50/16 radials...I brought the rpms to 2000 and when the light turns green...I give it a bit more gas and a little slip and I'm off...
I've always seemed to have the best look doing a little slip on radials...but you have DR's and could be a different scenario...
11sec87
161
ill
Sep 24, 2004
  • Sep 24, 2004
1.8s are respectable numbers. I had the my best 60fts side stepping the clutch at around 4000. stock suspension though.
good luck
11sec87
161
ill
Sep 24, 2004
  • Sep 24, 2004
sorry, that was a 85 302,t-5, not my 87.
90mustangGT
2,773
17
89
Dallas, GA
Sep 25, 2004
  • Sep 25, 2004
I'm just going to have to keep on trying new things I guess. I am going to try putting the controll arms on the other level to try to get it to hit the pavment harder.
_jb_
808
Michigan, Berrien County
Sep 25, 2004
  • Sep 25, 2004
Just play around with it...the car that is.
2006 S197 Gt Traction Issues!
  • Btrainfiveoh
  • Apr 26, 2016
3K
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2016
Svtpilot
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
need some help and advice
  • BlackO3GT
  • Sep 22, 2008
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 27, 2008
BlackO3GT
F
2010 Shelby Super Snake First Test
  • fox1x
  • Aug 12, 2009
  • 2010 - 2014 Specific Tech
5K
2010 - 2014 Specific Tech Aug 13, 2009
Buck Turgidson
New 10.5 Bogarts w/STIFF Sided slicks *PICS*
  • 04_snake
  • Sep 6, 2007
  • SVT Tech Forum
2K
SVT Tech Forum Sep 6, 2007
04_snake
