Left turn signal
Foxbody1995
11
48195
I finally got my turn signals to work after messing with them for a while. When i tested them the right turn signal works front and back
The left one does not.
  • Sponsors(?)
sams93gt
149
28
38
35
Did you check the relays , fuses and check the wires all the way back.)?
Shuttleman83
108
9
28
USA
It's the wires messed up or a short. You may have to take the individual wires out of the plug and test them, they will work right once you get the exact setup.
There are diagrams online but it takes trial and error.
kiddiccarus
The first widely accepted Tranny
1,779
1,114
143
30 Mins from a Ragged GT
www.angelfire.com
SOOOOOOOOO, Since a cracked screen has prevented this thread from moving anywhere.... (make sense though because no year was provided)
Have you thought of the multi-function switch? I had an issue on my 95 where:
  1. the right signal worked as it should by using the multi-function switch
  2. the left would only work, not blink when i held the multi-function switch
  3. the cruise control would shut off at any time you tried to signal left.
I replaced my multi-function switch and it all worked fine once again
Reactions: General karthief
General karthief
Mod Dude
Aug 25, 2016
19,279
6,404
193
polk county florida
he started two more threads about this issue, one in fox tech the other in fox gen talk, didn't see a resolution in either thread soooo :shrug:
Foxslider
im not that much of a idiot
Oct 25, 2019
530
158
53
33
Houston, TX
Flasher relay just fixed same issue for me. Course, check blinker bulbs first make sure one isnt burnt out.
Part # EL12. Novita. 20a, 2 way flasher. $14 @ oreillys.
Reactions: kiddiccarus
Dan2017
Texas Gulf Coast
If it's not blinking the front bulb may be burned out, if the indicator is blinking fast the rear bulb is burned out. If that's not it check the hazard flasher switch, make sure it's not depressed slightly.
General karthief
Mod Dude
Aug 25, 2016
19,279
6,404
193
polk county florida
