  • 1994 - 1995 Specific Tech
Line Lock question
  • Thread starter Thread starter milehighstang
  • Start date Start date Apr 22, 2005
milehighstang
54
littleton, colorado
Apr 22, 2005
  • Apr 22, 2005
hey i recently purchased a Moroso Line Lock kit from brothers performance and as soon as i get my new tranny put back in (hopefully monday!!!!) i would like to get the line lock kit the only problem i have is i dont know how to do it. I have the basic idea but if anyone has any instructions or tips or a complete walk through would be great. thanx again for your help you guys always come through for me.
milehighstang
54
littleton, colorado
Apr 22, 2005
  • Apr 22, 2005
anyone????
My95.0L
135
Ponchatoula, LA
Apr 25, 2005
  • Apr 25, 2005
Install the line lock after the ABS unit. Look for the line coming out that says "front". Cut line, install line lock, & light up those burnouts!
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Apr 25, 2005
  • Apr 25, 2005
Some people say that you have to install the linelock through the ABS system to work properly and safely. It's not true. I installed mine (and many have done this also.) directly at the proportional valve, even if I have ABS system. Never had a braking problem since I installed this. Here's a pic of my install. Neverming the "ugly" bend in my line. I was in a rush to install it cause I was going to the track that day.
Stangfreak95
add a 4
3,571
Apr 25, 2005
  • Apr 25, 2005
Here's another pic of somebody else's install.
My95.0L
135
Ponchatoula, LA
Apr 25, 2005
  • Apr 25, 2005
Stangfreak, does your ABS light ever come on? Mine comes on sometimes & then goes back off.
Stangfreak95
add a 4
3,571
Apr 25, 2005
  • Apr 25, 2005
No it never came on since I've own the car.
milehighstang
54
littleton, colorado
Apr 25, 2005
  • Apr 25, 2005
Thanx a million guys. you realy really helped me out!!!!!!!!!!!!!!!!!!
milehighstang
54
littleton, colorado
Apr 25, 2005
  • Apr 25, 2005
Stangfreak95 is there anyway you could give me a walk through from start to finish on the install. your picture really helped out and i know your probably busy but if you have the time and dont mind i would really apprectiate it
Stangfreak95
add a 4
3,571
Apr 25, 2005
#10
  • Apr 25, 2005
  • #10
Well I'll tell you what I know and it's not much cause it's been 2 years since we installed this. Well first of all, either you buy an install kit from Summit for example, or either you go to your local partstore and buy a few things. You'll need a couple 3/16in brake lines and propably a few different fittings. If you look at my 1st pic, you can see the 2 "NEW SHINY" lines coming out of the linelock. You dont need longer than that.
This is the pic of the Hurst installation kit, from Summit's website, which says that these are all the fittings required for this task for a mustang. They dont say the sizes unfortunately.
At least you can see what they look like. Try to match the sizes with the ones on my #2 pic. THAT PIC IS THE HURST WITH THE 3 IN/OUT. Your installation will be a bit different. My 1st pic is exactly how it is suppose to turn out, assuming your unit has only 2 "holes". Here's a good document for the installation of the linelock. The Hurst has 3 "holes" in it. I believe yours has only 2, like most of the kits. Ignore the part where they're talking about the PLUG that needs to be inserted.
http://static.summitracing.com/global/images/instructions/huu-5671516%282%291.pdf
You will need to have a flaring tool also. If you look at the second pic I posted, you can see, depending on what in/out, BUBBLE or DOUBLE flare. You have to flare a few lines for each specific input/output.
I'm very sorry for not beeing more helpful. The instructions I gave you are pretty complete though. If there's a specific detail you wanna know, maybe I can help you more than telling you the whole procedure.
milehighstang
54
littleton, colorado
Apr 25, 2005
#11
  • Apr 25, 2005
  • #11
Naw man dont be sorry. u helped me out a lot. Cool if i have a specific ? i will let you know, but for the most part i think i should be able to do it
My95.0L
135
Ponchatoula, LA
Apr 26, 2005
#12
  • Apr 26, 2005
  • #12
I would recommend installing it like StangFreak (before the prop. valve). Mine works fine (after the ABS), but like I mentioned I do have an intermittent ABS light since the install.
But damn I love that line lock!
G
2019 GT Line lock
  • gray owl
  • Jul 18, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jul 25, 2026
gray owl
G
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
94 GT Line Lock Question
  • SN95S550boy
  • Dec 4, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 5, 2024
AeroCoupe
