  • SN95 4.6L Mustang Tech
LOW FUEL PRESSURE 2000 GT
  • Thread starter Thread starter KW 2000 GT
  • Start date Start date Aug 18, 2008
K
KW 2000 GT
WEATHERFORD,TX
Aug 18, 2008
  • Aug 18, 2008
I am searching for a answer. GT randomly stalls at a stop. will fire right back up and may not do it again for 2 or 3 days. Fuel pressure is at 29-32 psi. I have replaced fuel pump, fuel rail pressure sensor, even installed a new pcm after getting a P0605 code. I also replaced fuel filter and new plugs.
streethorse
1,042
Dallas Texas
Aug 18, 2008
  • Aug 18, 2008
Sounds like the IAC valve. It will continue to get worse, until you get a new one.
D
darkside03gt
851
Sacramento CA
Aug 18, 2008
  • Aug 18, 2008
iac or a completely clogged air filter. did you replace your fuel filter too?
K
KW 2000 GT
WEATHERFORD,TX
Aug 18, 2008
  • Aug 18, 2008
THANK YOU
BobHyatt
378
  • Aug 18, 2008
Can also be the CCRM which contains the fuel pump relay among other things. When a pump goes out, it can become a heavy current draw and burn the relay contacts so that they become intermittent...
mogs01gt
3,113
30
119
Ohio
Aug 19, 2008
  • Aug 19, 2008
That psi is correct with the stock fuel pump
2000GTdriver
47
Mile High City, Colorado
Aug 21, 2008
  • Aug 21, 2008
Check for air leaks. Unmetered air getting into the motor can mimic IAC trouble. The engine contol computer seems to compensate for this while driving but has trouble at idle. My car had the same symptoms as yours and it turned out a vacuum hose under the hood somehow came loose on its own. I love a no-cost repair!
F
faststang_728
558
Greenbrier, WV
Aug 21, 2008
  • Aug 21, 2008
I've never heard of the CCRM what is that?
K
KW 2000 GT
WEATHERFORD,TX
Aug 23, 2008
  • Aug 23, 2008
THANK YOU WHAT VACUUM HOSE WAS IT?
K
KW 2000 GT
WEATHERFORD,TX
Jan 17, 2009
#10
  • Jan 17, 2009
  • #10
IT FINALLY GAVE ME A CODE, IT WAS THE CAMSHAFT SENSOR, IT HAD A SMALL CRACK IN IT
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
A
87 GT - Low Fuel Pressure Problem
  • Asbury
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
  • Gulftown980x
  • Jul 29, 2026
squeak93
