Low oil pressure
  • Thread starter Thread starter gungfusemaj
  • Start date Start date Mar 1, 2004
gungfusemaj
211
Bradenton Fl
Mar 1, 2004
  • Mar 1, 2004
I started noticing that my oil pressure is low almost to the red line it will jump up to the half way mark when give it gas but if i am at idle or idle speed going down the road it goes back down I do not know where to start looking for a problem.STOCK GAUGE
cardudeusa
1,744
Home of the Florida Gators!
Mar 1, 2004
  • Mar 1, 2004
I'd replace the oil pressure sender thats screwed into the block, its cheap and may fix your problem.
G
GATOR98GT
185
BRISTOL
Mar 1, 2004
  • Mar 1, 2004
Have you recently changed your oil and put in a differant kind, or a differant weighted oil?
351wRusty
29
Kelowna, BC
Mar 1, 2004
  • Mar 1, 2004
how many miles on your engine ?
gungfusemaj
211
Bradenton Fl
Mar 1, 2004
  • Mar 1, 2004
89grand
gungfusemaj
211
Bradenton Fl
Mar 4, 2004
  • Mar 4, 2004
OK the gauge only reads low after i have been running the car for a while "like the oil is HOT and THIN"??????I hada truck once that had a cracked piston ring and when the oil got thin I would of course loose all pressure together and dead on the road so before I go replacing sensor's do you think possibly There is something else
D
dfresh5050
106
  • Mar 4, 2004
i had the same thing happen and my engine was goin, do u blow any smoke??
Fox Saleen 163
286
San Diego, CA
Mar 4, 2004
  • Mar 4, 2004
My stock gauge use to do the same crap. Replaced it with an Autometer gauge and now it reads fine.
Greenracing
109
Puerto Rico
Mar 4, 2004
  • Mar 4, 2004
same here... replace to a mechanical gauge..
DTT92LX
185
Downingtown, PA
Mar 4, 2004
#10
  • Mar 4, 2004
  • #10
Mine did the same thing. Replace the oil pressure sender for $17 and all better. Stock gauge.
HISSIN50
34
129
Mar 4, 2004
#11
  • Mar 4, 2004
  • #11
even with a new sender, the stock gauge still sucks. get another guage. good luck.
saniutza
147
born in Transylvania, Romania...live in Lusby,MD
Mar 4, 2004
#12
  • Mar 4, 2004
  • #12
aftre i changed my intake manifold the gauge started acting weird... i got a new one and it works fine now... but you might wanna think about getting an aftremarket , don't trust the stock gauge...
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
