Lower end knock :(
  • Thread starter Thread starter jstang209
  • Start date Start date Aug 3, 2005
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 3, 2005
  • Aug 3, 2005
i took my car to the shop and found that i have a lower end knock in the engine.. they want 500 to check it out.. so i guess i have to do it myself.. could i just pull the upper and lower intake off and inspect.. or do i got to pull the whole engine out again.. that guy at the shop said it sounded like a rod knock or sumthing with a bearing, i cant exactly remember wat he was telling me.. so what should i be looking for?!
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Aug 3, 2005
  • Aug 3, 2005
Maybe a set of 20" wheels will help you
I would drop the oil pan and check to see if you have any play in your rods or if they are hitting on something, like the dipstick or what have you.
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 3, 2005
  • Aug 3, 2005
my dipstick is broke.. i have to shove it in the tube thingy.. and when i pull it out theres no oil on it.. but i no that theres oil in the egine.. i put 4.5 quarts
Black 93 Fox
1,995
Vancouver,Washington
Aug 3, 2005
  • Aug 3, 2005
I had a knock last september turned out the motor was dyeing. I just put my new motor in last month. I would pull the motor and check everything out in the bottom end.
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 3, 2005
  • Aug 3, 2005
so since its a lower knock, i cant pull off the intake and inspect from there? i really dont want to take the whole motor out again
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Aug 3, 2005
  • Aug 3, 2005
pulling the intake wont allow you to see the rods or crankshaft. probably gonna have to pull the motor
txstang84
1,639
42
69
Tuscola, tx
Aug 3, 2005
  • Aug 3, 2005
ditto...
when we pulled my friends engine (160K) out, he had a small knock that we correctly diagnosed as rod knock...his bearings were about half gone, nothin but copper on the #4, and #5 main bearings, and #4 and #8 rod bearings...they were gouged all to hell and the journals themselves looked pretty terrible too. The knock wasn't really all that bad either, you could hear it as it passed between 2k-3k rpm, and the only thing that kept it quieted down was 50wt oil...and he was really easy on it till we pulled it about two months later
but yeah, if you hear a rod knock, it's time to start searching out options for an engine swap, or at least a shortblock
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Aug 3, 2005
  • Aug 3, 2005
yea i just swapped this engine in.. my car was a 4cyl.. i guess this is why i got the donor car for 500.. good rearend and tranny bad motor.. atleast i could still use the intake and stuff if i just buy another block.. man this sucks!!
txstang84
1,639
42
69
Tuscola, tx
Aug 3, 2005
  • Aug 3, 2005
sorry dude,
you can always salvage the bottom end by getting the crank ground, rods resized and everything cleaned and balanced and drop it back in the cleaned block with new bearings and rings...
i dunno how much machining goes for in your neck of the woods, but here, the shop i take my engine parts to will ball hone the block, clean it, put in new cam brgs and freeze plugs, grind the crank, intall new rod bolts, resize the rods and clean and balance the whole assy for about $800...and provided the assy is correctly installed, all will be fine
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
