Lowering Blocks
  • Thread starter Thread starter NCMustang
  • Start date Start date Aug 23, 2004
N
NCMustang
54
Asheville, NC
Aug 23, 2004
  • Aug 23, 2004
Are there any cons to using lowering blocks? I have read where some people have had to use wedges after using lowering blocks, what is this all about? Thanks.
TIGGER
877
244
104
Portland, OR
Aug 24, 2004
  • Aug 24, 2004
I have 1 inch blocks installed in my 67 coupe. They have been there for 10 years and about 30K with no problems.
Route666
1,652
Brisbane, Australia
Aug 24, 2004
  • Aug 24, 2004
The only cons I could really see are the changed pinion angle, and the lengthened u-bolts required. The u-bolts would be more succeptable to flexing. To rectify the pinion angle problem, working out what angle you need and modifying your lowering blocks to give the required diff angle tweak would solve that problem.
SoCalCruising
2,437
SoCal
Aug 24, 2004
  • Aug 24, 2004
A lowering block creates a lever arm between the spring and the axle tube. The taller the block, the longer the lever. Under most circumstances this won't be an issue. IMHO, serious racers should avoid them, however. That said, I have de-arched 5-leafs and 1" lowering block and don't have any problems on the street.
mustang70
2,445
San Diego
Aug 24, 2004
  • Aug 24, 2004
I have 2" blocks on mine. Never had a problem. Even when I was using it as a daily driver.
G
GNN60GT500
1,218
26
48
5 car lengths in front of you!
Aug 24, 2004
  • Aug 24, 2004
1/2" blocks with no problems
65shlbycln
1,266
Atlanta
Aug 24, 2004
  • Aug 24, 2004
i use them.
N
NCMustang
54
Asheville, NC
Aug 24, 2004
  • Aug 24, 2004
Thanks for your replies. I will probably go ahead and order me a set of 1” lowering blocks and have them cut down to ½ “. One more question if I lower the rear with blocks, will it make the ride height in the front go up? Thanks again you guys always know the answers!
Route666
1,652
Brisbane, Australia
Aug 25, 2004
  • Aug 25, 2004
The front of the car above the axle won't go up, but the nose of the car will, pivoting over the front axle. It will be a tiny amount though. It would go up approximately (nose to front axle) / (front axle to rear axle) * amount lowered.
Lowering with blocks would have no different effect WRT the front height over lowering with lowered leafs.
one2gamble
902
Monterey
Aug 25, 2004
#10
  • Aug 25, 2004
  • #10
I use a 1inch block with mid-eyes...I need it to come down MORE
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Tuesday at 8:49 AM
squeak93
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
D
1996 gt mustang block temp vs coolant temp
  • Dkuehn
  • May 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 22, 2026
squeak93
