  • SN95 4.6L Mustang Tech
MAF screen?
  • Thread starter Thread starter 98BLKGT
  • Start date Start date May 23, 2005
98BLKGT
322
Chicago area
May 23, 2005
  • May 23, 2005
During my procharger install I noticed the MAF screen was not there. I think the previous owner took it out. If so, does anyone know where I can buy one or do you have one I could buy? Did my 02GT have a screen?
stangGT97
1,299
Boston area, MA
May 23, 2005
  • May 23, 2005
well, im sure you can pick one up from the dealership, but as long as you have a good airfilter on there, the screen is kinda pointless. the filter will stop mostly everything from coming into your engine, especially big stuff, and the screen will not prevent any small particles from getting into the engine, so i think its actually kinda pointless
M
mijo_latino
179
Canton, Michigan
May 23, 2005
  • May 23, 2005
from what i heard, the screens purpose is to slightly unify the air flow into the maf. Obiviously its not to stop any particles or what not. I don't know if there is a diffence in reading with or without it in place.
Orions98GT
234
Overland Park, KS
May 24, 2005
  • May 24, 2005
my 98 doesn't have a screen? maybe the previous owner stole it!
02GTKB
122
  • May 24, 2005
trash
CanadaStang
2,093
Mb
May 24, 2005
  • May 24, 2005
The screen is there to even out the airflow so incoming air flows even throughout the entire intake tube, giving the maf sensor an accurate reading of the airflow.
MT1083
1,033
Charlotte, NC
May 24, 2005
  • May 24, 2005
I would just go get one from the dealer. I doubt it would be very expensive....then again it is Ford.
ts1lmayb
67
Alabama
May 24, 2005
  • May 24, 2005
dunno if its worth the trouble unless you have crickets trying to get in your intake.....
98BLKGT
322
Chicago area
May 24, 2005
  • May 24, 2005
The dealer only sells it with a new mass air only. The reason why I need it is because:
1. The procharger tubing dont fit too perfectly together without it around the mass air. Might have a boost leak there.
2. I heard the intercooler makes alot of turbulant air comming at the mass air for a not-so-perfect reading.
3. Procharger instructions say it should be there.
MT1083
1,033
Charlotte, NC
May 24, 2005
#10
  • May 24, 2005
  • #10
Well if you are going to have to buy a new MAF, then you might as well upgrade to a 90mm that has a screen on it. I kept the screen with my KB because that was what was recommended because of the whole smoother airflow issue.
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
T
Digital Tuning Hello OBD2 problem
  • TNmach1
  • Sep 18, 2026
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
