MARK 8 FAN preferred years????
  • Thread starter Thread starter justintx75
  • Start date Start date Mar 13, 2009
justintx75
35
  • Mar 13, 2009
can someone explain to me the differences between the years and speeds--such as the 93-96's they spin slower so do they move less air or have a better pitch design so that it moves the same amount of air at a lower speed?
i heard that the 97-98 fans where made to run quiter-so is that why they spin faster do to blade pitch be less aggressive?????
to sum it up witch one is the better fan that cools the best?
part # is F3LY8C607A
93-96 use p/n F3LY 8C607 A @ 245.80
The 93-96 spin 1100 rpmson low and 1850 on highspeed.
97's use p/n F7LZ 8C607 AB @ 196.23
98's use p/n F8LZ 8C607 AA @ 140.11
The 97-98 spin 1800 on low and 2225 on high.
They all look the same, all come with a shroud. The 93-96 spin slower according to Ford Motorsport Tech line.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Mar 13, 2009
  • Mar 13, 2009
They are all superior to anything else there, so which you get doesn't particularly matter all that much. Either one would easily cool a powerful engine
But IIRC, the early fans were the better fan
justintx75
35
  • Mar 13, 2009
IIRC??? please explain?
93 LX
3,081
Norwalk, CA.
Mar 14, 2009
  • Mar 14, 2009
IIRC = If I Remember Correctly
justintx75
35
  • Mar 14, 2009
ok thanks..................
so does no one else run mark fans here??
StreetDreamsGT
449
New Jersey
Mar 15, 2009
  • Mar 15, 2009
I just grabbed one for 30 bucks from the junkyard , I haven't checked for fitment issues but I hear the fitment is really good, i'll let you know how it goes. Like everyone says though, you need to upgrade your alternator if you want to run one.
HISSIN50
34
129
Mar 15, 2009
  • Mar 15, 2009
They're supposed to all move the same air. The pitch is offset with the motor RPM, to supposedly equal things out.
justintx75
35
  • Mar 15, 2009
so witch ones move the most air the 93-96 or 97-98's?
HISSIN50
34
129
Mar 15, 2009
  • Mar 15, 2009
1990MustangLX50
89
#10
  • Mar 15, 2009
  • #10
I use a fan off of a 96 and it cools great best fan for 30 bucks from a jy
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 16, 2009
#11
  • Mar 16, 2009
  • #11
Just FYI (for your information.. ),
Last time i went hunting for the Mark fans, i came across the 4.6 Thunderbird fans, which are physically identical to the Mark fan. The only difference between them is the motor...the Mark fan is a variable speed motor whereas the Tbird is a 2 speed like the Taurus fans are. I've had several Mark fans and i can guarantee you the Tbird fan puts out the exact same amount of air as the Mark fan...the only difference is that you get your choice of speeds. You could run it on low and still cool better than 99% of the other fans available out there. Considering how common the 4.6 Tbirds are vs. the Mark VIII...this in my opinion is something everyone should take notice of as they're super easy to find.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Mar 16, 2009
#12
  • Mar 16, 2009
  • #12
I use a 94-95 SN95 e-fan.
The taurus 3.8L fan is another good fan to use.
Any of these fans will be fine for cooling off a 5.0 motor.
justintx75
35
#13
  • Mar 21, 2009
  • #13
ok thanks for the info guy's
justintx75
35
#14
  • Mar 21, 2009
  • #14
do you run it on low or high?what fan controller?dcc?
1990MustangLX50
89
#15
  • Mar 22, 2009
  • #15
It is run on high using a cheap controller from autozone for the time being and so far no issues
