mass air conversion
  • Thread starter Thread starter cdiehl30
  • Start date Start date Nov 6, 2007
C
cdiehl30
  • Nov 6, 2007
I have an 88 gt. I am wanting to convert this car to mass air. I have already ordered an a9l computer. What else do I need? Can i get this stuff from the junk yard? How long does this take to complete, and how hard is this? Also, where can i find directions?
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 6, 2007
  • Nov 6, 2007
you will need a mass air harness or a mass air conversion harness obviously a mass air meter that matches your injector size and map sensor for mass air. you will need to change up some vacuum lines and your intake piping. you can find these in a junk yard or from Ford Fuel Injection, or painless and finally it will take the better part of a day to lay everything out and fasten and hide wires to your liking.
Vinnietbird
584
  • Nov 6, 2007
I did the conversion on my car in about 2 hours,including hooking up the MAC CAI kit,installing the new computer,and pulling the vacuum line from the MAP sensor and installing a plug where that vacuum line originated from.I used a kit for the Conversion I got off Ebay.I think it was about 430.00.Instructions were included.Solder and heatshrink the wires that you have to splice together.There was only 6 wires for me to deal with.2 wires were moved in the computer plug,2 were added from the new Mass Air harness,and two were spliced for hot and ground.easy stuff.
fastnotch2002
9
ohio
Nov 6, 2007
  • Nov 6, 2007
Done it on my old 88, pretty simple and straight forward, check ebay for the kit.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 6, 2007
  • Nov 6, 2007
you don't "need" a complete harness
my friend did his 87 and just had a MAF sensor and spliced it into his 87 harness. just need to swap a few pins around on your ecm plug
Vinnietbird
584
  • Nov 7, 2007
X2.Easy stuff if you just take your time and pay attention to the pins in the harness you are dealing with.Like I said,move 2,add 2,splice 2.Done.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 7, 2007
  • Nov 7, 2007
MASS air conversion instructions from http://www.stangnet.com/tech/maf/massairconversion.html FREE
A9L (5 Speed) computer from junkyard $100-$150
A9P (Auto or in a pinch, 5 Speed) computer from junkyard $100-$150
70MM MAF from 94-95 Mustang GT - $40-$70
MASS Air wiring harness kit $30-$85
The whole thing is probably less than $300 using junkyard parts.
A9L computers are 5 speed only
A9P computers are automatic, but will work with a 5 speed.
The conversion harness seems to work well for most folks. It avoids the compatibility problems in using a harness from the junkyard. Simple and cheap, actually less work that swapping the wiring harness.
Conversion Harness kits & parts
http://www.mass-air.com/
http://fordfuelinjection.com/index.php?p=54
If the idea of moving & soldering wires scares you, here's a list of compatible Mass Air wiring harnesses.
Copied from bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Larger MAF to go with Mass Air conversion:
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
*1.) Metal flange adapter http://www.kustomz.com/cat3.html Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
Vinnietbird
584
  • Nov 7, 2007
This will save you a LOT of time and money...item #280169090685 on Ebay.It's a Mass Air computer (A9L) and harness from a '91 Mustang.22 hours left to bid,and it's $140.00 buy it now.
308stang
  • Nov 7, 2007
i jus did the maf convertion on my 87',but when im on the gas it suppuders like if its running out of gas.what could it be? i got stock injectors but the maf is bigger,could that be it.im going crazy!!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 8, 2007
#10
  • Nov 8, 2007
  • #10
The only MAF that is a one for one swap for a 93 and earlier 5.0 Mustang is the 94-95 Mustang MAF.
The MAF body and sensor are designed to match each other. Therefore you can't swap sensors between different part number MAF bodies and maintain proper calibration. The assembly is designed to match the computer’s internal program, and swapping a different MAF can upset the computer's calibration. In other words, your monster MAF probably won't match the calibration of your 5.0 Mustang computer.
308stang
#11
  • Nov 8, 2007
  • #11
oh ok i get it.so in other words i should get a stock maf and that can help my problem? or what should i do?
Black1987Stang
1,422
Jersey Shore
Nov 8, 2007
#12
  • Nov 8, 2007
  • #12
The maf conversion is easy as cake, the hardest problem I had was getting the wires through the firewall rubber plug hah. I got a few stock maf's if anybody needs one for their conversion.
And for 308stang if you have a maf not calibrated for your injectors then it's not going to run right. Let me know if you need one.
88mouse
630
Mooresville nc
Nov 8, 2007
#13
  • Nov 8, 2007
  • #13
that harness won't work. The only maf harness you can use with out changing the dass harness to is an 89. 90 is a year of its own and 91 and up are the same.
Vinnietbird
584
#14
  • Nov 10, 2007
  • #14
I didn't know that harness wouldn't work.On my '88 T-Bird,I just bought the kit off Ebay and did my own conversion.Doing the conversion is one of those mods that when you finish it,you wonder why you didn't do it a lot earlier.
vristang
4,933
101
124
Seattle
Nov 10, 2007
#15
  • Nov 10, 2007
  • #15
Start by telling us exactly what parts you have..
ecu catch code?
diameter of MAF tube?
part number of MAS (MAF sensor)?
jason
308stang
#16
  • Nov 10, 2007
  • #16
well i bought the maf off some guy,he told me the sensor its self is stock but not the meter.he didnt tel me what size it was,but ill ask him.as far for my mustang,i have a 308 with stock heads and manifold.im trying to make the motor come alive! i got msd wires,cap and rotor,i have the distributer but i havent instralled it. i got a c&l intake tube with a k&n flter.pretty much thats it.im just trying to get my car running right
vristang
4,933
101
124
Seattle
Nov 11, 2007
#17
  • Nov 11, 2007
  • #17
While the above does help a little...
We NEED to have the following...
ecu catch code?
It sounds like you may have a C&L MAF tube. Check the bottom side of the aluminum housing for a 'C&L' cast into the housing.
For this, part numbers are required.
jason
308stang
#18
  • Nov 12, 2007
  • #18
yeah i have a c&l tube.ill check to get some numbers.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
How to convert Speed Density to Mass air - Complete walk thru!
  • TTSaleen
  • Sep 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
TTSaleen
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
N
Thermostat housing
  • nataliaisafraid
  • Dec 8, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 2, 2026
Cmrd
C
J
WTB Help!!! Need to find interior rear quarter panels - gray for a 1990 Mustang GT hatch
  • Jtlyle78
  • Jan 17, 2026
  • Want to Buy
Want to Buy Jan 22, 2026
KRUISR
