Mass Air flow Conversion Please help
  • Thread starter Thread starter Shrek86GT
  • Start date Start date Aug 9, 2007
1 of 2 Next Last
Shrek86GT
15
Panama City FL
Aug 9, 2007
  • Aug 9, 2007
I have a 86 GT and i put a 93 mass air wire harness in it.
My problem is this no fire from the coil. I have power but no fire.
Do i put a swicth wire to the relay by the ecu. or what? if any one can help please let me know.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 9, 2007
  • Aug 9, 2007
Did you swap out the computer too, and rewire the pins for Mass air?
http://www.stangnet.com/tech/maf/massairconversion.html
88mouse
630
Mooresville nc
Aug 9, 2007
  • Aug 9, 2007
you need a 89 harness. Or a 91-93 dash harness.
vristang
4,933
101
124
Seattle
Aug 10, 2007
  • Aug 10, 2007
I am getting ready to go through with a MAF conversion myself.
Why can't the original SD harness be re-pinned?
Why the requirement to run a specific year harness?
Thanks,
jason
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 10, 2007
  • Aug 10, 2007
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 10-Aug-2007 to add compression test for engines that have had the heads removed or valves adjusted.
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 10, 2007
  • Aug 10, 2007
Thanks,
jason
I'm also preparing to do this conversion. From the research I've done, it seems the only harness you need is the MAF harness (4 wires) that get pinned into the existing EEC harness.
Shrek86GT
15
Panama City FL
Aug 11, 2007
  • Aug 11, 2007
Is there any way of making my 93 harness work. With out having to use the 93 inside harness. In my 86 GT.
I have the complete ecu & harness out of a 93 GT . What else do i need to do. Can any on tell me
Hizzle
51
Fort Carson, CO
Aug 11, 2007
  • Aug 11, 2007
Thanks,
jason
Check the instructions posted in the link further up on the page, that's what I went off of for mine. Worked fine. As far as those pins, go to Auto Zone, they have them in stock in their electrical section. The 4 wire Harness I got already had them on it. You may need them if you do the "additional recommended step" in there from the VSS and the fuel pump relay. I did not need to do these with mine and it runs fine. It is a non-cruise car fromthe factory with a 5spd. Don't know if that helps.
Shrek86GT
15
Panama City FL
Aug 11, 2007
  • Aug 11, 2007
Thanks for every ones help.
vristang
4,933
101
124
Seattle
Aug 12, 2007
#10
  • Aug 12, 2007
  • #10
Shrek,
My apologies for the side track here...
Did you get the car to start?
Have you been able to pull KOEO diagnostic codes?
Let us know,
jason
Shrek86GT
15
Panama City FL
Aug 12, 2007
#11
  • Aug 12, 2007
  • #11
Not yet got to pull the starter. Having problems with it now. If it is not one thing its another.
? do i have to use the inside 93 wire harness. Or can i bypass that .
I have the out side already installed.I have power every were it counts.
if any one knows let me know.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 12, 2007
#12
  • Aug 12, 2007
  • #12
The 93 harness is supposed to be compatible with the 86 body except that you need to make sure that the fuel pump relay is plugged into the under the hood socket in the 93 harness. Also make sure that you have the EEC relay located over the top of the computer present.
How the TFI ignition works in 86-93 model Mustangs:
Tools needed: DVM, noid light, safety pin.
Theory of operation:
The TFI ignition in 86-93 Mustangs has 4 main components: the ignition switch, the coil, the TFI module and the PIP sensor inside the distributor.
The ignition switch gets power from the two yellow wires that are supplied power by a fuse link located in the wiring harness that connects to the starter solenoid.
The coil is mounted on the driver’s side strut tower on most EFI Mustangs. It gets power from a red/green wire and a brown/pink wire from the ignition switch. That wire from the ignition switch feeds a 20 gauge blue fuse link that connects to the red/green wire. The fuse link protects the wiring and the ignition switch, since the fuse link for the two yellow power supply wires has a much higher current rating. Without the smaller fuse link protecting the smaller wiring used in the ignition circuit, a short there would cause the red/green wire to overheat and burn up.
The TFI module is mounted on the side of the distributor and supplies the ground for the coil. Every automotive power supply circuit uses the ground as the return path to carry power back to the negative side of the battery. The TFI switches the tan/yellow wire coming from the coil to ground. It gets power from the red/green wire when the ignition switch is in the Run position. The red/lt blue wire supplies a signal to turn on more power (dwell time) when the engine is cranking. The trigger signal comes from the PIP sensor when cranking and the computer when the engine is running. The SPOUT jumper plug enables computer controlled spark advance. When the SPOUT is removed, spark advance is locked at the setting determined by the mechanical position of the distributor.
The PIP sensor is in the bottom of the distributor under the shutter wheel. It is a Hall effect magnetic sensor that senses a change in the magnetic field when one of the slots in the shutter wheel uncovers the sensor. Then it supplies a pulse that triggers the TFI module to provide a ground to the ignition coil. A bad PIP will often set code 14 in the computer and cause hot start problems. Replacing the PIP sensor requires removal of the distributor and pressing the gear off the distributor shaft to expose the sensor. For most people, a remanufactured distributor ($55-$75) is the solution, since they may not have access to a press.
Troubleshooting the ignition system – no spark or weak spark. All the tests are done with the ignition switch in the Run position unless specified otherwise. A safety pin may be used to probe the wiring connectors from the back side.
1.) Check for 12 volts at the yellow wires on the ignition switch. No 12 volts and the fuse link near the starter solenoid has open circuited.
2.) Check for 12 volts on the red/green and brown/pink wires coming out of the ignition switch. No 12 volts, replace the ignition switch.
3.) Check for 12 volts at the ignition coil. No 12 volts and the blue 20 gauge fuse link has open circuited.
4.) Check for 12 volts at the red/green wire on the TFI module. No 12 volts and you have wiring problems.
5.) Remove the small red/blue wire from the starter solenoid (looks like it is stuck on a screw). This is a safety measure to keep the engine from turning while you are making measurements. Have a helper turn the ignition switch to Start and look for 12 volts on the red/lt blue wire on the TFI module. No 12 volts and you will have starting problems, but push starting the car will work OK. No 12 volts, replace the ignition switch. Be sure to reconnect the red/blue wire to the starter when you finish.
6.) A noid light available from any auto parts store, is one way to test the PIP pulse. The computer uses the PIP signal to trigger the fuel injectors. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the PIP is working. No flash from the noid light and the PIP is suspect. To confirm the PIP is being the source of the non flashing noid light, look for 12 volts on the red injector wiring. Good 12 volts and no flashing noid light means the PIP has failed.
7.) Remove the SPOUT plug from the harness and try to start the engine. If it starts, replace the PIP. This is a common no start condition when the engine is hot.
8.) The TFI module is a go/no go item when you have a no spark/weak spark condition on a cold engine. It either works or it doesn’t.
The TFI failure mode on a running car is usually a high speed miss on a warm engine. Many auto parts stores will test your TFI module for free. Bring along a hair dryer to get it hot while testing it and run several test cycles, since it often gets weak when it heats up.
The coil is somewhat more difficult to pinpoint as a problem. A good coil will make a nice fat blue spark 3/8”-1/2” long. The problem is that one person’s perception of a fat blue spark looks like may not be accurate enough to spot a weak coil. The coil is cheap enough ($13-$16) that having a known good working spare might be a good idea.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Shrek86GT
15
Panama City FL
Aug 12, 2007
#13
  • Aug 12, 2007
  • #13
Thanks for this info.This will help.
88mouse
630
Mooresville nc
Aug 12, 2007
#14
  • Aug 12, 2007
  • #14
When i did my conversion i when and got a brand new 90-93 wireing harness and it had two plugins over next to the driver side hood hinge. And the dash harness plugins only one. (maybe the other way around) But the car wouldn't start. So i just put my old SD harness back in and did the conversion. I didn't add any pins, I just spliced in to the wire that my direction told me to and for the fuel pump i just straight wired if from under the seat at the pump relay(so that the fuel pump is on when the key is on).
Shrek86GT
15
Panama City FL
Aug 13, 2007
#15
  • Aug 13, 2007
  • #15
What conversion did you go with 88 mouse .
Let me know.
Thanks
tkareno
67
clinton ct
Aug 13, 2007
#16
  • Aug 13, 2007
  • #16
good information
88mouse
630
Mooresville nc
Aug 13, 2007
#17
  • Aug 13, 2007
  • #17
A kit like this: http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_750880_-1_10435
tkareno
67
clinton ct
Aug 13, 2007
#18
  • Aug 13, 2007
  • #18
yea
Shrek86GT
15
Panama City FL
Aug 15, 2007
#19
  • Aug 15, 2007
  • #19
I got that one before i got the wecked 93 mustang. It did not come with instructions
on how to install it do you have them 88 mouse.
let me know were to go to get them.
Shrek86GT
15
Panama City FL
Aug 15, 2007
#20
  • Aug 15, 2007
  • #20
Thanks for all the great info guys.
1 of 2 Next Last
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
