Mass Air flow Conversion Please help
  • Thread starter Thread starter Shrek86GT
  • Start date Start date Aug 9, 2007
First Prev 2 of 2
88mouse
630
Mooresville nc
Aug 17, 2007
#21
  • Aug 17, 2007
  • #21
I still got mine i will have to dig them out from where i moved the other week.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 17, 2007
#22
  • Aug 17, 2007
  • #22
Two plugs on the dash harness soulnds like a 90 model harness.
Copied From bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
Computers from 89-92 are all the same. Look for the A9L sticker on the back cover for a 5 speed that matches your requirements. Example: E9ZF 12A650 AA" with the A9L code.
88mouse
630
Mooresville nc
Aug 17, 2007
#23
  • Aug 17, 2007
  • #23
Red Wire: Must be spliced into pin 37 or 57 on the mass-air compuiter 60-pin connector.
Black Wire: Must be spliced into pin 40-60 on the mass-air computer 60-pin connector.
Brown Wire: Terminal must be inserted into lacation 9 on the mass-air computer 60-pin connector.
Blue Wire: Terminal must be inserted into location 50 on the mass-air computer 60-pin connector.
3 additional wires w/ terminals attached (for some vehicles):
Pre-1989 vehicles may need to have other wires connected to avoid poor vehicle performance and/or EEC error codes. If there are no terminals in the pin holes listed below, you will have to add these wires. Also, if your car does not have cruise control, you may have to add the speed sensor in the transmission. You'll need the speed sensor, and electrical connector, and new speedometer cable. This is available as an optional kit, or you can get it from your ford dealer.
Fuel Pump Monitor: Pin 19 is the fuel pump running monitor. It goes from pin 19 on the Mass-air computer connector to the PK/Bk wire (Splice into the wire - it's the fuel pump hot (+)wire) under the drivers seat. (this wire must be added)
Vehicle speed sensor wires: Pin 6 is the VSS ground wire. Splice this wire to the O/Y wire (-) on the vss at the back of the transmission. Pin 3 is the VSS hot wire. Splice this wire to the DG/W wire (+) on the VSS at the back of the transmission. If pin 3 & 6 already have terminals inserted in them, then skip this step.
Also, the following thermactor pump wires must also be moved on the mass-air computer connector:
Pin 51 must be moved to pin 38 in the mass-air computer connector
Pin 11 must be moved to pin 32 in the mass-air computer connector
I copyed it word for word. But i just connected the four wires for the mass air plugin. Then i took my seat out and cut the pink wire on the fuel pump relay and, ran a wire from there to the fuel pump. (Its on when the key is on now) Then i grounded the other wire on the frame next to the fuel tank.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 17, 2007
#24
  • Aug 17, 2007
  • #24
It sounds like you bypassed the inertia switch and the fuel pump control relay.
Now the ignition switch has to carry an extra 12-18 amps of current that it was never designed to carry. That will make for other stange electrical problems as the ignition switch gets older and starts to heat up due to the extra electrical load.
Bypassing the inertia switch means the fuel pump will not shut off if the car is in a collision. That increases the possiblity for a serious fire since the pump will have electrical power anytime the ignition switch is on. All in all, very poor practice.
Shrek86GT
15
Panama City FL
Aug 17, 2007
#25
  • Aug 17, 2007
  • #25
Thanks I will try this out .
I will let you know.
M
motocrossed733
79
#26
  • Aug 18, 2007
  • #26
maf problems
I just repaired a car like this first did you use the same computer as the wiring harness, if you used the same eec and complete harness, it should work, did you have to cut any wiring at all? check the injector pulse wiring and does your fuel pump come on?
88mouse
630
Mooresville nc
Aug 18, 2007
#27
  • Aug 18, 2007
  • #27
Yeah i know it not the right way. But i only had one night to do it sense its my DD. Now that i swaped everthing over to the notch, Im going to wire it like it should be.
Shrek86GT
15
Panama City FL
Aug 23, 2007
#28
  • Aug 23, 2007
  • #28
It's a live I say It's a live !!!!!!!!!!!!!!!!!!
Thanks to every one with all you guys help.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 23, 2007
#29
  • Aug 23, 2007
  • #29
What was the final thing that fixed your problem?
Shrek86GT
15
Panama City FL
Aug 27, 2007
#30
  • Aug 27, 2007
  • #30
Its done my baby is back on the road.
88mouse
630
Mooresville nc
Aug 27, 2007
#31
  • Aug 27, 2007
  • #31
What was the probablem like jrichker said?
Shrek86GT
15
Panama City FL
Aug 28, 2007
#32
  • Aug 28, 2007
  • #32
CONVERTING YOUR SPEED DENSITY 5.0 MUSTANG TO MASS AIR FLOW SYSTEM
Author: Mike Stowe
Mustang Mass Air Conversion
In this document, I will outline the steps to convert a speed density mustang to the MAF system. I am generating this because I felt the documentation I had to work with could be improved. This is based on my own personal experience converting my 88LX convertible to MAF and the instructions that came with the kit I bought. The color codes of the wiring are what I saw in my car and may not be the same but probably are. This document is for reference only and I accept no responsibility for what you do to your car.
REQUIRED COMPONENTS: You will need to obtain a Mass Air meter, a MAF computer and the electrical harness for the MAF meter. The meter harness can be purchased from several manufacturers for about 50-60 dollars but you can make your own if you wish. There are a few EEC's that can be used depending on the car. I've heard it doesn't matter manual vs. auto tranny but I don't know for sure so this is just some additional info for you.
For older MAF computers, the numbers are:
Manual transmission hard top:E9ZF 12A650 AA
Manual transmission convertible:E9ZF 12A650 BA
Automatic transimission:E9ZF 12A650 CA
For later (early 90's I think) MAF computers, the numbers are:
Automatic transimission:F3ZF 12A650 BA
Manual transmission:F3ZF 12A650 AA
Universal EEC:F3ZF 12A650 DA
You can also use the 93 cobra computer:F3ZF 12A650 CA but it requires MAF calibrated for 24# injectors.
The MAF mounting bracket and associated plumbing between the throttle body and the air filter box will have to be acquired from a junk yard or you can rig up your own setup. If you intend the to do the "optional" signals mentioned later, you'll also need to obtain 3 EEC connector pins and some wire.
NOTES: Average mechanical skills are about all that is needed. The only special skill I suggest you have to do this conversion is soldering. Crimp connections are unreliable and could lead to future troubleshooting headaches which you should avoid.
1. EEC REMOVAL
Before you begin, disconnect the battery. Remove the passenger side kick panel. There is 1 screw and a push-in fastener that secure it. Remove the screw in the white plastic retainer that holds the EEC in place. There was a ground wire and a relay, each one screw that I had to move out of the way so I could get the old EEC out. You should now be able to pull the EEC down and out. Once the EEC is out, remove the EEC harness connector using a 10mm socket to loosen the bolt in the center of the connector.
2. MAF HARNESS INSTALL
You'll need to run the 4 wire MAF meter harness through the fire wall on the passenger side. I suggest you poke another hole in the large oval grommet the existing EEC harness goes through located in the upper corner on the passenger side of the firewall. I popped the grommet out of the firewall with a screwdriver and used an exacto to poke a hole in the thin section. You don't just want to blindly jam something through there because you may cut the insulation on some of the wires and cause future shorts. I then used a wire coat hanger as a snake, poking it through the grommet and coming out by the EEC inside the car. I taped the MAF meter harness to the snake (protecting the EEC pins) and pulled it through from inside the car. Pop the grommet back into the firewall after the harness has been pulled through. I then used some silicone to seal the area where the new harness goes through the grommet so I didn't get any water leaks. Remove the red "H" shaped plastic pin lock in the EEC connector. Gently pry around the plastic pin lock with a pointed awl or small scewdriver working it up and out of the connector. You can't add or remove EEC pins to the connector without removing this lock. Depending on the MAF meter you have, it may have a 4 or 5 pin connector. Refer below for pin locations.
PIN
5-Pin connector (E4FB 14489 BA)
4-Pin connector (F078 14489 BA,E9DA 14489 BA)
A
Power (+)
Power (+)
No connection
Ground (-)
C
Ground (-)
Signal (-)
D
Signal (-)
Signal (+)
E
Signal (+)
a. The Power (+) wire from the MAF meter harness needs to be spliced into the existing red wire in position #37 of the EEC connector.
b. The Ground (-) wire from the MAF meter harness needs to be spliced into the existing black/green wire in position #40 or #60 of the EEC connector.
c. The Signal (-) wire from the MAF meter harness needs an EEC pin which then gets inserted into position #9 of the EEC connector.
d. The Signal (+) wire from the MAF meter harness needs an EEC pin which then gets inserted into position #50 of the EEC connector.
The locations for pin #9 and #50 should be empty. The pin numbers are embossed into the plastic connector on the back of it where the pins insert. It's a little hard to see but they are there if you look closely.
Please note that the notches shown in the diagram are not the ones seen in the picture. The ones in the diagram are actually keys that only permit the connector to be installed into the EEC one way. Pins 20,40, and 60 are closest to you in the picture. It should be obvious because the pin locations for the additional signals must be empty.
3. MAF METER INSTALL
Remove the existing air filter box cover and tube leading to the throttle body. Install the MAF to the passenger side strut tower which should already have the holes for the bracket. Connect the duct work, tighten the clamps and connect the meter to the MAF meter harness.
4. THERMACTOR PUMP PIN MOVES
You will need to move the 2 signals for the thermactor pump to different locations in the EEC connector. The EEC pins are held in place by a hook shaped retainer that snaps into a groove in the EEC pin. To remove you must pry the hook back from the EEC side of the connector and either push on the pin or pull on the wire from the back. I used a paper clip and flattened one end but a small jewelers screwdriver would work also. The wire currently in position 51 tan/red needs to be moved to position 38. The wire currently in position 11 green/black must be moved to position 32. If there is not enough slack for this to reach the new location, you'll have to splice in some extra wire. Mine reached without doing this.
The next 2 steps some consider optional but will generate error codes in the EEC. Others have reported stalling problems without the VSS signals. In my opinion it's worth doing if only for piece of mind and no bogus error codes. In preparation for these signals, remove the driver's seat and the driver's side kick panel. There are 3 wires that will need to be added for these signals with EEC pins on one end. I suggest you tie them all together and route them as one cable over to the EEC on the passenger side. I took this opportunity to change the carpet at the same time so I had most of the interior out which made this fairly simple.
5. FUEL PUMP MONITOR SIGNAL
This signal called FPM2 is used to monitor the voltage going to the fuel pump. It will generate an error code in the EEC if it's not connected but "shouldn't" cause a problem. Splice into one of the 2 pink/black wires going to the relay located under the driver's seat and insert the other end into position 19 of the EEC connector. Refer to figure 1.
Figure 1 (Relay under driver's seat)
6. VEHICLE SPEED SENSOR SIGNALS
These signals are required for cruise control and as stated earlier, some have reported stalling problems on cars not equipped with cruise so avoid the head-ache and just do it. These will also generate an error code in the EEC if not installed. These signals come from a sensor that plugs into the transmission. The easiest place to tap into them is behind the driver's side kick panel. There is an 8 pin connector cable which runs back to the driver's seat, across the floor under the seat then back towards the front of the car and then goes through the transmission hump to the sensor. You will need to splice into the orange/yellow wire. The other end of this signal needs an EEC pin attached and this gets inserted into the EEC connector into position 6. You need to splice into the dark green/white wire for the other connection. The other end of this signal needs an EEC pin attached and this gets inserted into the EEC connector into position 3. Refer to figure 2.
Figure 2 (VSS signals behind driver's kick panel)
7. COMPUTER INSTALL
Put the red H shaped pin lock back into the EEC connector. Bolt the connector to the new MAF EEC and slide the EEC back up in place. Install the bolt for the EEC retaining bracket and any other relays/grounds you may have removed to get the old EEC out.
8. MAP SENSOR
The manifold absolute pressure (MAP) sensor is located on the firewall next to the vacuum tree. Disconnect the vacuum line from the sensor going to the intake and plug the line going to the intake so you don't have a vacuum leak. Leave the port on the sensor open and DO NOT disconnect the electrical connection to the sensor.
MAP Sensor on firewall
Congratulations! You should now be done with your MAF conversion. I suggest you re-check all your wiring changes at this point before you re-connect the battery to avoid a smoke show of a different sort. Once you are happy that everything is correct, re-connect the battery and start the car. The car may idle a bit rough for a while until it relearns, but severe idle or drivability problems may indicate a real problem.
Author: Mike Stowe
Got a tech article you want to share? Submit it to SN
StangNet.com A Division of Drive9 Media
© Copyright 1998-2005 All Rights Reserved.
All trademarks referenced herein are
Shrek86GT
15
Panama City FL
Aug 28, 2007
#33
  • Aug 28, 2007
  • #33
Come to find out it was one little wire.
The power relay buy the ECU the pink and black for the coil and dist.
First Prev 2 of 2
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
