mechanical advance only?
  • Thread starter Thread starter tylerrocks
  • Start date Start date Aug 4, 2006
T
tylerrocks
514
Big Spring, TX
Aug 4, 2006
  • Aug 4, 2006
Is there any con to running mechanical advance only? I can get 24* initial and 32* total this way.
Tyler
Vinyl66
398
  • Aug 4, 2006
That sure is a lot of initial timing. Anywhere from 32-36 is a good general range for total.
It will not hurt anything to run without vacuum advance. Most aftermarket distributors do not have them.
But vacuum advance does raise the timing under part throttle conditions (driving down expressway) to extend the burn cycle which results in better gas mileage.
mfp4073
387
Hells Ditch, FL
Aug 4, 2006
  • Aug 4, 2006
mech advance only on my MSD billit distributor. The dyno numbers were showing better without it with my motor combo.
T
tylerrocks
514
Big Spring, TX
Aug 4, 2006
  • Aug 4, 2006
Cool, It sure is alot more fun to drive this way.
Thanks,
Tyler
mfp4073
387
Hells Ditch, FL
Aug 4, 2006
  • Aug 4, 2006
when I got to looking at my curves, I found that from idle to operational speed, I needed to go to full advance as fast as possible. Used the light springs and heavy weights and disconnected the vaccuum completely.
Max Power
1,774
St Paul
Aug 4, 2006
  • Aug 4, 2006
It's do-able, but you have to set up the entire curve for it.
24 initial is a LOT and may cause starting problems.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Aug 4, 2006
  • Aug 4, 2006
24* initial is about double what most people run...it may work at idle, but I think you'll have low RPM pinging.
The advantage to running vacum advance (along with mechanical) is improved fuel economy.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
