Mechanical Guages Need Help!!
  • Thread starter Thread starter Nopantz
  • Start date Start date Feb 19, 2007
Nopantz
234
NJ/US Merchant Marine Academy
Feb 19, 2007
  • Feb 19, 2007
Well for XMAS I received Mechanical Fuel Pressure, Oil Pressure, and Water Temp gauges. I have the Water Temp and Oil Pressure gauges already mounted in the Gauge and the Fuel Pressure Gauge is mounted in a cup on the cowl. My problem is I am basically a newbie when it comes to anything under the hood and I have little to no clue where to wire them up. I am pretty sure that the Oil Pressure wiring goes somewhere around the Oil Filter, but that is all I know.
If someone could send me pictures of where they need to be wired or give me a good description of where that would be greatly appreciated. Thanks guys!
stevesLX
373
cincinnati
Feb 19, 2007
  • Feb 19, 2007
Whats your email address I will send you photos. I take it were talking 302 correct
Nopantz
234
Feb 19, 2007
  • Feb 19, 2007
yep 302 thats much appreciated......my email address is Steven.Stockl.2009@usmma.edu
HISSIN50
34
129
Feb 19, 2007
  • Feb 19, 2007
If any info is needed to augment Steve's stuff, a search will reveal a ton of threads, many of which are quite articulate.
Good luck.
Nopantz
234
Feb 19, 2007
  • Feb 19, 2007
okay Steve sent me some good info on the Oil Pressure Guage. I still need info on the Fuel Pressure and Water Temp. guages. I did a search and all I could find was stuff about electric gauges mostly not much on mechanical gauge install
I just need to know location and such of install
HISSIN50
34
129
Feb 19, 2007
  • Feb 19, 2007
It's out there. I was just searching for about FP gauge mounts and plumbing adapters last night.
I know I've personally flogged the water temp stuff repeatedly in the past.
I bring that up just to let you know the info is there if you need it ASAP.
Good luck.
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Electrical Oil Pressure Gauge IN Dash Cluster Unresponsive
  • Nine Finger Wrenching
  • Jan 7, 2025
Fox 5.0 Mustang Tech Jan 8, 2025
85GTStangGuy
