Mis matched injectors
  • Thread starter Thread starter 302GT
  • Start date Start date Apr 12, 2005
302GT
81
Carson City,Nv.
Apr 12, 2005
  • Apr 12, 2005
I noticed when I bought my car that it had wet injectors and that they were mismatched,some black,some brown.After I drove the 500 miles home they stopped leaking and haven't leaked since.Will it hurt anything driving it like that for a little while or should I get a matched set now?Would there be a power increase?
_jb_
808
Michigan, Berrien County
Apr 12, 2005
  • Apr 12, 2005
I would get a match set. I bought my OEM ones for about $230 if I remember right. I ran with some other injectors for a few days before, and it backfired like hell, no power, ect.
And yes, I changed them because they were leaking. Turns out the plastic at the top of the injector was cracked and leaking, and I thought it was the O-Rings. After the third set of different brand O-Rings, I just bought new injectors.
Mustang5L5
Mod Dude
Feb 18, 2001
43,336
18,062
224
Massachusetts
Apr 12, 2005
  • Apr 12, 2005
The old '88 leaky injector syndrome.
I beleive there was a TSB on 1988 models having leaky injectors. Mine had them as well.
Swap em out for some good matched 19#ers
302GT
81
Carson City,Nv.
Apr 12, 2005
  • Apr 12, 2005
I might get some this weekend.Probably the ford racing 19's.Think that might boost my hp a little?
_jb_
808
Apr 13, 2005
  • Apr 13, 2005
no
Mustang5L5
Mod Dude
Feb 18, 2001
43,336
18,062
224
Massachusetts
Apr 13, 2005
  • Apr 13, 2005
No, it's what you had stock.
I wouldn't even waste my time buying new 19#ers. If you are going to buy brand spanking new injectors, get some 24#ers and buy a new MAF calibrated for them (or get a chip burnt)
Then you have adequate fuel for future mods.
Or you can just buy a used set of 19's for now. You can get newer low milages ones from new GT's. I beleive up to 2002 had the 19's.
My 2003 has pink injectors...which are either 19 or 21#. I forget which.
_jb_
808
Apr 14, 2005
  • Apr 14, 2005
He would have to upgrade to MAF before going to 24#.
302GT
81
Carson City,Nv.
Apr 14, 2005
  • Apr 14, 2005
The car is sd right now and I will convert when I go with the turbo 347 next winter.
Mustang5L5
Mod Dude
Feb 18, 2001
43,336
18,062
224
Massachusetts
Apr 15, 2005
  • Apr 15, 2005
Leave the injectors that are on it now. They may look nasty but they are not hurting you. They just ooze a bit.
Save your money and use it to buy 24's next winter and do it right. There is no reason to buy a new set of 19's now.
gregpro50
140
Binghamton NY
Apr 15, 2005
#10
  • Apr 15, 2005
  • #10
If it runs OK and they stopped leaking then why fix something that isnt broke ?? I would just drive on them. Especially if you plan to build up next year.
302GT
81
Carson City,Nv.
Apr 15, 2005
#11
  • Apr 15, 2005
  • #11
I figured I would wait so if you guys think it will be ok then I'm fine with it.It runs great but wanted to make sure.Thanks
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Apr 15, 2005
#12
  • Apr 15, 2005
  • #12
sounds wierd that they are mismatched.....i thought they were color-coded.....but if its coo.....its coo
302GT
81
Carson City,Nv.
Apr 15, 2005
#13
  • Apr 15, 2005
  • #13
Well,all but one are brown and the one in the front on the drivers side is black with a blue ring around it.I am guessing that it went bad and the previous owner replaced it.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
