  • 1994 - 1995 Specific Tech
missing when hot
  • Thread starter Thread starter oxfordgt
  • Start date Start date Jul 6, 2006
1 of 2 Next Last
oxfordgt
288
Clarksville, TN
Jul 6, 2006
  • Jul 6, 2006
my buddy has a 94 5.0 and it is overheating and we cant figure it out. he now says it is missing when it gets up to temp. Any suggestions?
302RollinHard
Columbus, OH
Jul 6, 2006
  • Jul 6, 2006
The TFI is very susceptable to heat. I would think that would be the missing problem, as for the overheating (which I would be more concerned about) more information is needed to have an opinion of the problem. ( what was changed before the problem, if anything, if the system will pressure test (are there leaks) etc.
oxfordgt
288
Clarksville, TN
Jul 6, 2006
  • Jul 6, 2006
Im not a 5.0 guy and not sure what a TFI is. Im trying to get more info on the overheating
blacksheep2
9
  • Jul 6, 2006
well the car in question happens to be my ride there was some leaks the around the thermostat the goosneck was warped i replaced that also the radiator had a leak and i replaced that also as far as a system will pressure test i have not had that done yet
legalize420
1,541
South Florida
Jul 6, 2006
  • Jul 6, 2006
when you added the coolant did you burp the system?
WHITE94COBRA
816
HUNTINGTON BEACH
Jul 6, 2006
  • Jul 6, 2006
I'm dealing with a warped head on my dads camaro right now, It overheated and warped the heads, so were getting a bad miss....
oxfordgt
288
Clarksville, TN
Jul 7, 2006
  • Jul 7, 2006
anybody else have any ideas?
blacksheep2
9
  • Jul 10, 2006
burp
yes I did do that. yesterday i flushed the system again and still she is running hot.
Jeffrostang
335
Richmond, VA
Jul 10, 2006
  • Jul 10, 2006
My car is doing the same thing... I replaced the water pump and now it runs even hotter. Not sure how to fix it either
HISSIN50
34
129
Jul 10, 2006
#10
  • Jul 10, 2006
  • #10
BS2, does it consistantly miss when hot?
First thing is pull codes (even if your CEL is not on). While doing so, get the car to miss and run a cylinder balance test.
The TFI idea is a pretty good one. The parts houses will often test them for free. In your case, You'd ask them to test it multiple times to heat it up.
Anything else is just gonna be wild guessing. Folks need more info to go on.
Good luck and welcome!
BlackVert
5,589
9
98
Bethesda, MD
Jul 10, 2006
#11
  • Jul 10, 2006
  • #11
mine was missing when hot and it was a couple of bad spark plug wires
good luck
blacksheep2
9
#12
  • Jul 11, 2006
  • #12
hot in c-ville
i have had the codes read and none come up even while hot im at a loss as to what to do next
Jeffrostang
335
Richmond, VA
Jul 11, 2006
#13
  • Jul 11, 2006
  • #13
My temp is way high when it is hot out and the other day in the late evening(cooler), the car didn't even get up to temp. Was just over the normal line the entire trip. I'm going to replace the thermostat just to eliminate it and its good insurance anyway.
BlackVert
5,589
9
98
Bethesda, MD
Jul 12, 2006
#14
  • Jul 12, 2006
  • #14
done the tuneup stuff lately? replacing the spark plugs, wires, rotor, cap, fuel filter, clean the maf ... ?
blacksheep2
9
#15
  • Jul 13, 2006
  • #15
doing it
I am going to be doing tis to day also i am going to replace my computer or ecm hope this works.
blacksheep2
9
#16
  • Jul 14, 2006
  • #16
still hot & missing
did all that except the ecm and im still missing not runing as hot but still up there
blacksheep2
9
#17
  • Aug 2, 2006
  • #17
hot no more
well come to find out that my fan was not kickning on and my radiator had a crack in it im still heasitating got no clue have changed plugs wires and even the coil what next
HISSIN50
34
129
Aug 2, 2006
#18
  • Aug 2, 2006
  • #18
Nice work so far - you're replacing stuff that needed replacing even if it didnt help your miss.
If not mentioned: if it misses consistantly at idle, I'd run a cylinder balance test (it's the computer's way of figuring out which cylinder is missing and to what degree).
You do it as part of the code retrieval process (after KOER, as I recall). Takes 1 minute and gives great info that otherwise can take awhile to ascertain.
Good luck with it.
QUIKSVT
93
#19
  • Aug 2, 2006
  • #19
just out of the blue.. what are you running your timing at???
blacksheep2
9
#20
  • Aug 3, 2006
  • #20
timing
as of this moment i am wating on a timing light to find out the answer to that question as it stands now ... at idle runs great but when i try to get on her she is heasitating dont know why but the miss is gone now but now i have major heasitation............. Help
1 of 2 Next Last
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
9
91 LX 5.0 getting hot when a/c is running
  • 91lx14gt5.0s
  • Jun 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 4, 2026
manicmechanic007
P
New here
  • PortCity
  • Jun 9, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 9, 2026
AeroCoupe
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
