  • 1994 - 1995 Specific Tech
missing when hot
  • Thread starter Thread starter oxfordgt
  • Start date Start date Jul 6, 2006
First Prev 2 of 2
HISSIN50
34
129
Aug 3, 2006
#21
  • Aug 3, 2006
  • #21
BEFORE you start hosing with your timing setting, I'd either confirm the balancer hasnt slipped a little and/or make a scribe of where your dizzy is in relation to the lower intake.
If your HB started to slip, the timing light will mislead you and where you think your timing is set. Having that initial reference will allow you to get back to where you are now.
Good luck.
blacksheep2
9
#22
  • Aug 4, 2006
  • #22
Good luck.
Thanks for the tip I will rember that. also how would i check that the h. balancer has not sliped?
HISSIN50
34
129
Aug 4, 2006
#23
  • Aug 4, 2006
  • #23
If your timing is way off from where it should be (your timing light shows something real weird), that's a sign.
The elastomer between the two halves is known to crack as it ages, which is what allows the outer ring to slip in the first place. This can also allow the outer ring to slide longitudinally (like someone hit one part of the outer ring with a hammer from the front).
Those are the biggies I look for.
Good luck.
blacksheep2
9
#24
  • Aug 4, 2006
  • #24
Good luck.
thanks for the help ill be looking tonight i hope
First Prev 2 of 2
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
9
91 LX 5.0 getting hot when a/c is running
  • 91lx14gt5.0s
  • Jun 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 4, 2026
manicmechanic007
P
New here
  • PortCity
  • Jun 9, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 9, 2026
AeroCoupe
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
