missing
  • Thread starter Thread starter nasty93
  • Start date Start date Sep 25, 2006
nasty93
9
rogers,ar.
Sep 25, 2006
  • Sep 25, 2006
hi i'm chris. I have a question. I have a miss or stumbile at part throtile. My plugs all look good as do the cap rotter, and wires. Timing is at 14. and fuel pressure is at 38( no vac.). tps is at .99 at idile. Any help is appreciated.
Fett
766
  • Sep 25, 2006
I had the same issue, and spent quite a lot of time trying things and testing things. It ended up being one of the easiest things to try....you can go try this right now.
Take the vac line off your EGR and block it off. You can stick it on the bolt that holds the AC accumulator to the firewall, as it is close and will block off the line nicely.
Now go take the car around the block and see if you are having the same problem.
The EGR has a few common issues, one of which being a "dead spot" in the sensor. Basically the EGR starts to open while cruising, but it hits the dead spot and the PCM adds more vac to open it up further, the EGR goes past the dead spot and is open too much, so the PCM takes vac back and the EGR closes too far...because it keeps going back and forth over the dead spot. Thus the surge while crusing. With the vac line off it can't do it, and the problem will go away....IF that is your problem.
Like I said, it is an easy test that will only take a few minutes with no tools. It might work, it might not...but it's worth a quick try. It solved my problem.
nasty93
9
rogers,ar.
Sep 25, 2006
  • Sep 25, 2006
Thanks. But i have the egr hose off becouse the egr switch is stiking. That was one of the thangs that i thout about. thanks for the advice. I think it grate to have place to go and ask for help. and to be abile to help otheirs who are in to the same thang that i am.
HISSIN50
34
129
Sep 25, 2006
  • Sep 25, 2006
Though you checked, have you looked for a Peter Pan light show at night with misted water on the plug wires?
Sorry but I had to ask.
Good luck.
AZNEAL311
85
Phoenix
Sep 27, 2006
  • Sep 27, 2006
Anyone know how much pressure should be in the EGR vac. line? I took mine off while idleing and there was very little air flow. So i revved the engine up and failed to notice an increase in air flow. EGR switch maybe?
Fett
766
  • Sep 27, 2006
There shouldn't be much, it only opens while crusing.
HISSIN50
34
129
Sep 27, 2006
  • Sep 27, 2006
Agreed. There is no vac in the line to my EGR at idle.
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
C
For Sale Mint 1993 Calypso 5.0 Convertible
  • Chrispy62
  • Aug 22, 2026
Fox Body Mustangs For Sale (1979-93) Aug 22, 2026
Chrispy62
C
Engine Light throttle miss
  • Dontknowchit
  • Jul 7, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
AeroCoupe
