Progress Thread Monkeybutt2000's 89 vert build thread- MURPHY"S LAW
  • Sponsors(?)
kiddiccarus
The first widely accepted Tranny
1,080
559
133
30 Mins from a Ragged GT
www.angelfire.com
my helper for the day
This here makes me smile. Bonding time here and having someone who is willing to lend a hand, learn, turn a wrench makes all of these projects just that much better. My son has been right with me on all of my projects and we have thrown tools, drank Mike's piss, and cussed about skinned knuckles. He is not a Mustang Owner yet, but in time I am sure the Convertible will be in his name and I will finally have a Coupe. Is she actually interested in working on cars or just helping for the day?
Reactions: Rdub6
Monkeybutt2000
270
205
53
48
Lafayette,IN
She LOVES the car,working on it,not so much. However,she likes to learn things and I'll be damned if I'm gonna raise kids that don't know how things work. I would love to find another clean body and have both my kids restore it,with my guidance of course.
74stang2togo
Oooh! CT!!!
Mod Dude
Mar 7, 2002
7,429
3,306
224
I doubt that,..all you guys drink Bud Light...
You sir, are quite mistaken. I'm a whiskey drinker. When I do stoop low enough to drink beer, it's usually Pacifico or Shiner.
I'm a whiskey guy
There's hope for you after all.
IPA all the way :banana::banana::banana:
Every IPA I've tried tasted like it had soap in it.
Haha,how do you think I afford all this stuff? I drink Busch Light :D
Save the money you're spending on that and drink water, you'll never know the difference.
Monkeybutt2000
270
205
53
48
Lafayette,IN
Got the TKO bolted up. Ran into a snafu,and it was totally my fault. Tried using the stock T5 bolts,they just weren't jiving. Removed trans and lo and behold, Lakewood bolts are 7/16-14,ugh. I managed to bugger up a hole,so had to tap. So sourced new bolts and got her back together. Now,I have to punch the oil pan for the turbo feed line,and it'll be ready to drop back in.
Monkeybutt2000
270
205
53
48
Lafayette,IN
Just a heads up. I used the engine lift plate from Jegs,worked great. However, I overlooked the part about what intakes it fits. It does NOT fit the Trick Flow lower. Of course I figure this out after I received it. I had to modify every hole to make it work.
On another note,had to file unemployment today. Rumor is we're not going back til May 4th.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,128
6,022
204
31
Hillsborough county
You will likely need to use a stifflers crossmember or make your own. sometimes you can get lucky and pop the welds on the crossmember tubes and slide it back. Yours looks to be about as far off as mine was when i did the 4r70w install.
Monkeybutt2000
270
205
53
48
Lafayette,IN
That's the thing,I already ground the welds and pulled it all the way back. Was just surprised it was off laterally.
Monkeybutt2000
270
205
53
48
Lafayette,IN
I got the hotside installed,and started on the coldside. I'm not a fan of how the oil return line is constructed. Instead of a barb a threaded fitting would have been much easier. I fought that stupid clamp for awhile,when you would tighten it the excess end would push on the turbo flange,in turn spinning it toward the turbo retaining bolts.
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
5,302
4,351
203
42
On my car I had to trim the cold pipe that connects to the intercooler passenger side. I think it was because of the height of my intake with a 1 inch spacer. You can see where I added the piece cut off to the pipe by the TB.
Just letting ya know incase you run into a similar issue.
The bypass hose rides on the bottom of the alternator. Squeezes it shut to take belt off. Some folks use a different hose and route it towards the front and up and over to the heater pipe assembly. I left mine alone but installed vinyl sleeving to help protect the hose. No issues. This stuff...
Thread starter Similar threads Forum Replies Date
F What's it Worth? Red on red 1984, GT vert, 5.0, 26k miles What is it Worth?!?!? 0
Z Rebuilding my 1994 GT 'Vert 1994 - 1995 Specific Tech 5
W HELP: 2007 Vert Leaking Above Passenger Door 2005 - 2009 Specific Tech 0
M Mag’s 86 Vert build thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Justin87 Engine Annoying motor mount question (vert or poly) clearance concerns. Fox 5.0 Mustang Tech 1
foxbodybill89 Interior and Upholstery 89 vert rear quarter panels Fox 5.0 Mustang Tech 3
9 Paint and Body Vert Top Interchangibility From 02 to a 98 1996 - 2004 SN95 Mustang -General/Talk- 3
Z Good Exhaust Aftermarket for 02 vert GT The Welcome Wagon 1
cameronc77 '88 GT vert 302 build 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
G Fox 88lx vert top issues 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
F For Sale 2003 Mustang GT Vert with very low miles (21K)-Well taken care of SN95 Mustangs For Sale (1994-04) 1
C '01 'Vert- 5.3 LS/T5??? 1996 - 2004 SN95 Mustang -General/Talk- 2
S 87 GT vert weatherstripping 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Slow92Vert Progress Thread 92 GT Vert a lot of TLC required. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
MrPerfect2 Fox How to soften the ride on a 91 vert ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
Slow92Vert New Member The Welcome Wagon 2
D Hello from Mid-Michigan. 98 GT vert The Welcome Wagon 3
O Paint and Body WHATS THE DIFFERENCE IN 89 GT HATCH AND VERT SPRINGS 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
FastDriver SOLD 1991 5 spd 5.0 LX vert $5,000 Fox Body Mustangs For Sale (1979-93) 9
N New guy, bout to get teenage dream: Triple Black GT (prem) 'vert ('05). What should I get first? 2005 - 2014 S-197 Mustang -General/Talk- 5
5 New member from Alberta 7UP Vert The Welcome Wagon 9
gearhead77 General clean-up 89 GT 'Vert questions. Mustang Sound & Shine All 0
M Electrical 2011 GT vert. rear window problem/can bus gremlins 2010 - 2014 Specific Tech 1
C 89 GT Vert - Finally cleaned it up and took pics 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
cameronc77 Fox '88 GT Vert engine swap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
M Interior and Upholstery Help 93 LX Vert Fox 5.0 Mustang Tech 0
D 1992 GT Vert from NWI The Welcome Wagon 1
X Progress Thread 91 LX Vert "Super Slow" Resto/Build 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
B 93 gt vert The Welcome Wagon 7
ChillPhatCat Progress Thread Haven't posted in a looong time... rescuing another 'stang... '89 Vert 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
G Electrical SN95 vert 3.8L rebuild, no spark, stumped! 1994 - 1995 Specific Tech 0
gearhead77 Interior and Upholstery 89 GT Vert Door card suggestions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
cameronc77 1988 GT Vert rear seat belts swap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
JJP3 Paint and Body Cervinis ram air hood on a 94 'vert 1994 - 1995 Specific Tech 6
L Another rubbing thread - 88 GT Vert lowered with 235/55 x17s 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
J 2002 gt vert instrument cluster issues SN95 4.6L Mustang Tech 1
F 99 cobra vert price help 1996 - 2004 SN95 Mustang -General/Talk- 3
J Engine 1989 Gt vert stock heads valve spring help Fox 5.0 Mustang Tech 1
N Progress Thread My first fox. 88 vert 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
N 88 Vert from Nashville. The Welcome Wagon 3
R Engine 95 gt. Vert. Cam suggestions Fox 5.0 Mustang Tech 4
D 2000 GT 'vert 1996 - 2004 SN95 Mustang -General/Talk- 1
S Project Resto - Supercharged 1992 GT 'Vert 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 150
R3DSoxFRESH Exhaust 1989GT VERT top wont go up or down Fox 5.0 Mustang Tech 3
Dontknowchit For Sale Interior vert plastic Interior Exterior Parts 0
realtex 95 GT vert- airbag code 12 1994 - 1995 Specific Tech 1
kiddiccarus Progress Thread 1995 3.8L Vert (2002 3.8L Dual Port Engine) 1996 - 2004 SN95 Mustang -General/Talk- 33
C Paint and Body 89 LX Vert - rear glass separating from top Fox 5.0 Mustang Tech 7
Lovejoy SOLD 89 LX 5.0 Vert Fox Body Mustangs For Sale (1979-93) 4
billison Vert /ttop door glass, run channel install question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
