more weird problems....grrrrrrr
  • Thread starter Thread starter randyb1976
  • Start date Start date Feb 11, 2009
R
randyb1976
  • Feb 11, 2009
well once again im having some sort of problem... i got the timing fixed and though all was good....heres the problems now
when car is cold and started..for about the first mile it misses bad..then all of a sudden car picks up and smoothes out. doesnt do it when it warmed up..only when it sits for awhile..what can cause this??
when driving it seems to have decent pickup..revs to 5 grand with no problem but seems like its sitting still..believe its part of the above problem
found some issues...iat senser was broke..replaced it...no difference
the temp gauge goes to 140 all day long...verified that temp at sensor.. possible tstat?? or lack there of??...could the low temp be causing the weird running issue?
also found 2 bolts on the upper intake were stripped and loose...cant verify an intake leak though...is it still possible there could be a small leak??
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 11, 2009
  • Feb 11, 2009
Use a vacuum gauge to determine if there is a leak - you should see 16.5"-18" of vacuum at 650-725 RPM. Use motor oil in a squirt can and squirt any suspect areas. The engine will change speed if the leak tries to suck up the oil. Do not use flammable liquid or propane to find leaks. A flash fire is a good hair removal method, but it is also painful and costly.. Ask Richard Prior about that...
No vacuum leaks found? Then dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
R
randyb1976
  • Feb 11, 2009
ive checked for vacuum leaks and have none...also used scan tool for codes...had all egr due to no egr valve..no other codes for anything else
R
redknight290
26
  • Feb 11, 2009
It is quite possible that your barometric pressure sensor is giving a false reading. Your car would misfire roughly until the EEC went into closed loop mode, after that it would adjust itself. i would recommend checking that.
Black1987Stang
1,422
Jersey Shore
Feb 12, 2009
  • Feb 12, 2009
so the coolant stays at 140 all the time even after runnin for a while? Is the top radiator hose warm? howd you check the sensor, ohmeter?
Get that working properly first before trying to fix the missing problem....you should at least have a thermostat, I would put in a 180 the lowest, or a 195.
R
randyb1976
  • Feb 12, 2009
the hose gets warm but not hot...pulled the tsat out tonight and i had to really push hard to get the spring to move..like it was stuuck tight... also on the intake at the front there is a sensor that a little elbow goes on..believe its for the gauge...there is also one on the rear of the intake but no wire is on it...found an orange wire that looks like it should go there but someone splice it to a ground...does this sound right?
HISSIN50
34
129
Feb 13, 2009
  • Feb 13, 2009
If the front sensor looks stock, and the stock wiring (with the little rubber elbow) is there, that's for the stock gauge. The rear port originally had a square headed plug but it sounds like someone put an aftermarket sender there and then removed the gauge. Note that the rear port sucks for accuracy. I would put the inaccurate stock sender back there and lengthen the wire. Then put an aftermarket gauge's sender in the front (originally) stock location.
The orange wire is probably your HEGO ground, which should be grounded to the intake or head.
R
randyb1976
  • Feb 13, 2009
the senser n the rear looks just like the front...if that isnt used for anything ill just let it alone..... where is the barometric pressure sensor located??
HISSIN50
34
129
Feb 13, 2009
  • Feb 13, 2009
What year of stang are you working on? Note electrical mods like mass-air conversions, etc.
The BAP is on the firewall, It's a dark rectangular looking box.
R
randyb1976
#10
  • Feb 13, 2009
  • #10
I HAVE A 90 GT.. i found the barometric sensor..its right on the firewall...is there anyway to test or should i just replace??
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
