MS3 Goldbox help?
James408
14
New York
Let me just start by saying I did check and it is a good oem ford iac for 1986 mustang. It was operating properly on the old a9l ecu but it does have that inline resistor right before the plug to the iac. So unless that resistor is effecting it I dont know why the ms3 goldbox isnt really communicating with it? I can get the car to start run and idle pretty smooth once it settles but im working out another issue. Reading like 75 to 80 degrees after idling for a long time like 30 plus minutes and car is very very warm like up to or above full operating temp. So I think sensor maybe bad or something skewing reading there causing rich running condition fooling ecu into thinking cars colder than it is... Car info is has a aem 30-4110 wideband calibrated to ecu. Tps is working and calibrated to ecu. Timing locked to distributor timing matched together when ecu in locked Timing. Afrs generally very rich around 11 to 12 flucuating alot at idle and under very light throttle drive around the block was like 10 to 12 afrs some 13s but very light throttle and low rpms. So im assuming the ecu seeing cold temps like 75 degrees from sensor is the rich running issue right now?
  • Sponsors(?)
James408
14
New York
Have you done any tuning on the main VE table? the base tune is just there to get you started, its up to you to get the AFR dialed in.
I was starting on the main ve table and got the idle very smooth with no surging at all right around 850rpms. A bit on the rich side like an 12 to 13 afr at idle but sound really good. I tried taking it for a very short ride (barely a mile) to get gas. Stayed low rpms very light throttle. Afrs where ok in low roms but once I started working into anything above 2500 rpms I'm seeing 11.5 even 10 afr so very rich. I'm assuming thats because of the ect sensor telling ecu its like 75 degrees fully warm. I checked with a infrared thermometer on the crossover tube where sensor is and reading 180 to 190 degress fully warm so maybe sensor is going bad and cant read higher temp ranges. Every time i try to lean out my ve table cells afrs slowly fall rich again I'm thinking possibly from the temperature sensor issue? I tried to sweep the iac valve with locked timing and engine rpm did not change so maybe my settings are wrong for the idle control circuit?
James408
14
New York
Ah ok I was not understanding, yes the wrong information from the ECT will keep warmup enrichment active. your thoughts are correct
Ok so ect will be my first priority then. Thank you for helping clarify that I'm pretty lost with alot of this being so new to it lol. Now just got to figure out why I cant sweep the idle air control valve seems like ms3 goldbox having trouble communicating with it. If its not the settings as I tried all different frequencies and normal and inverted settings still cant sweep it I should probably make sure the thing is still good first. Next nice day going to test it with a dmm
Thread starter Similar threads Forum Replies Date
T MS3 AC Idle Up Settings Digital Self-tuning Forum 1
T MS3 Gold Box (87-93 Mustang) - IAC Valve Mode Question Digital Self-tuning Forum 4
beyondEOD Fuel Pressure Sensor with Megasquirt Digital Self-tuning Forum 15
beyondEOD 94-95 Mustang 5.0 AODE MS3 Gold Box w/ Microsquirt Digital Self-tuning Forum 62
mustang70 MS3 Newbie Digital Self-tuning Forum 33
GodStang Setting up injector data on MS3 and Tuner studio (03 Cobra) Digital Self-tuning Forum 23
91mustanglxcoupe 89 Mustang MS3 gold box tuner studio idle control and injector dead time Digital Self-tuning Forum 15
awing awing's 347 ms3 v3 Digital Self-tuning Forum 15
a91what Service Provided Megasquirt ECU support and Tuning Services - Tuning, Welding, Mechanic, Body Work... 5
Black1987 PiMPxs vs MS3 (Pro?) vs PNP MS2 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 69
wiseguyk 1991 Turbo 306 coupe MS3/PiMPxs tuning adventure Digital Self-tuning Forum 263
a91what Megasquirt/tuner Studio Tech Thread Digital Self-tuning Forum 16
M Looking for clips to attach the rocker panel moldings and trim on a 1970 Mach I - any help is apprciated Classic Mustang Specific Tech 0
C Engine 88 GT donor swap help Fox 5.0 Mustang Tech 5
P WTB/Trade HELP!! Iam doing v8 swap Mustang II Parts 0
A Exhaust Loud popping noises help Fox 5.0 Mustang Tech 10
F Help needed 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
T HELP MY CAR IS RUNNING TERRIBLY! 1996 - 2004 SN95 Mustang -General/Talk- 0
silverlx50 Engine Help with jrichker's injector testing, more details please Fox 5.0 Mustang Tech 0
R Please Help! Ideas/Tips on how to make my '93 2.3l (NA) Convertible Faster. 2.3L (N/A & Turbo) Tech 6
A Electrical Help. I’ve about had it with this car.... Fox 5.0 Mustang Tech 12
M Electrical Little ecu wiring help, almost there! Fox 5.0 Mustang Tech 0
9 Engine HELP - Fuel Line to Fuel Rail Questions Fox 5.0 Mustang Tech 0
T Help! 1996 - 2004 SN95 Mustang -General/Talk- 0
A Tire Help 2005 - 2009 Specific Tech 1
A Exhaust Vacuum lines help Fox 5.0 Mustang Tech 3
H Suspension help wanted Fox 5.0 Mustang Tech 18
9 Can someone help me with my tune. Digital Self-tuning Forum 7
2Blue2 Help I want to put this T5 in our Cobra II 1974 - 1978 Mustang II Talk & Tech 67
D Need sct x4 users help please. Digital Self-tuning Forum 0
E I need help with my AC system 1996 - 2004 SN95 Mustang -General/Talk- 5
B 1994 mustang cooling fan wiring? PLEASE HELP!! 1994 - 1995 Specific Tech 0
A 93 fox build help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
L Help with trunk wires 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
sams93gt Engine Valvetrain help please!! Fox 5.0 Mustang Tech 8
G Engine Need help with cooling system issue Fox 5.0 Mustang Tech 12
Mystang66 Brake Booster help 1974 - 1978 Mustang II Talk & Tech 7
B Help out a newb... SN95 4.6L Mustang Tech 4
J Body Work in OC Services - Tuning, Welding, Mechanic, Body Work... 0
PayUpSuka V1 S-trim tune help Digital Self-tuning Forum 4
M Electrical HELP PLEASE! A/C Blowing hot air! 2005 - 2014 Specific V6 Tech 3
markinms Engine surges, cutouts, rough running during acceleration - Help Please! Fox 5.0 Mustang Tech 5
J Please help - 68 Convertible J-Code confirmation/value 1965 - 1973 Classic Mustangs -General/Talk- 1
L Help with TrickFlow Top End Kit Fox 5.0 Mustang Tech 6
N Need Help w Heater Blower Failure 1994 - 1995 Specific Tech 13
J 96 cobra - Electrical Gremlins HELP! SN95 4.6L Mustang Tech 1
L Help with identifying wires in engine bay Fox 5.0 Mustang Tech 1
B Help! 1994 - 1995 Specific Tech 1
K Please Help!! Shifting from 1st to 2nd 2015+ (S550) Mustang -General/Talk 1
Jetzv8 2014 Mustang radio not working. NEED HELP Mustang Sound & Shine All 0
